How to Manually add marker/pointer to Arcgis Map using X/Y Coordinates
8528
7
07-08-2013 07:31 PM
LeoQuah
I am trying to use OneMap(Singapore Map) multi route function.
The multi route function is completed but it only shows the route and no pointers/markers
Since OneMap is develop using Arcgis map, arcgis manual marker should be able to be implemented into OneMap.
How can i add markers into a map using X/Y Coordinates?
Thank you
KenBuja
MVP Esteemed Contributor
LeoQuah
Here are two samples that show how to add points to a map programmatically
https://developers.arcgis.com/en/javascript/jssamples/graphics_svg_path.html
https://developers.arcgis.com/en/javascript/jssamples/map_topo_graphics.html
Hi ~ Thank you very much~ But i tried the code and put locations in Singapore but the marker did not appear. Do you know why?
LeoQuah
Currently i tried the links and i put the coordinates of location in Singapore but it cannot be use.
KenBuja
What are the coordinates that you're putting in? Are they latitude/longitude coordinates or in another projection?
Radheshsoni
i copied the coordinates from google map . can to defined how can i convert them for arcGIS map.
LeoQuah
Hi
I am using X/Y Coordinates as OneMap(Singapore Map) uses X/Y coordinates
Thank You
KenBuja
Please show the code you're using to put the points on your map.
