How to launch login straight to external OAuth identity provider
10256
11
06-20-2018 09:00 PM
by Anonymous User
Not applicable
Hi all.
This question relates to using OAuth with ArcGIS Online.
The standard workflow using OAuth as I understand it is:
My question is, how do you skip the first step? I want an application to jump straight to displaying the external login page.
I can't seem to figure out how to trigger the OAuth workflow without the user first seeing the AGOL page and manually clicking the button to launch the external login page.
cheers,
-Paul
Tags (3)
Ranga_Tolapi
Hi AlecPatrizio1
We are also facing an issue similar to yours (as given below). Can you please share if you have any updates. Thank you.
When I request an access token from Azure AD (using my client app id), and then register this token with the JSAPI IdentityManager, when calling portal.signIn(), i get a 'token is invalid' response. Not sure what I'm missing.
MelvinSuratos
Any solution this? I'm in the same situation.
