How to implement a legend from a static image
1333
12-07-2010 02:14 PM
StephenLead
Honored Contributor
The new legend widget works well when using a legend defined in ArcMap.
I need to use a complicated legend, which has been created in a graphics package and provided as an image.
I thought of storing it in a geodatabase, serving it via ArcGIS Server, and displaying it in a static map frame.
Any better/easier ideas?
Steve
derekswingley1
Perhaps I'm missing something, but you're talking about putting an image on a web page, correct? Just put an img tag in a div and you're good to go.
StephenLead
Honored Contributor
Hi Derek,
Yeah, I should have provided more details about what I'm trying to do.
For reasons I don't fully understand (the map is part of a larger and more complicated site) it isn't possible simply to say <img src="geology_legend.jpg">
The images for the legends will need to be stored in a database rather than as simple images in a directory. I figured it might be possible to use ArcGIS Server as the database and server.
I'll post back if we end up finding a solution.
Steve
