i need to display photos in info template.can any one tell me how to do it
Hi Veena,
I found the following sample on GitHub:
Add an attachment image to popup infoWindow for ArcGIS JavaScript API. · GitHub
Here it is an example of the code converted to AMD:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Sample Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body, #mapDiv { padding:0; margin:0; height:100%; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map, popup, featureLayer; require([ "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Popup", "dojo/dom-construct","dojo/on", "dojo/domReady!" ], function ( Map, FeatureLayer, Popup, domConstruct, on ) { popup = new Popup(null, domConstruct.create('div')); map = new Map('mapDiv', { basemap: 'streets', center: [-74.0499, 40.0403], zoom: 17, infoWindow: popup }); on(map, 'load', function (_map_) { featureLayer = new FeatureLayer('http://services.arcgis.com/dlFJXQQtlWFB4qUk/arcgis/rest/services/ResidentialBuildings/FeatureServer/...', { mode: FeatureLayer.MODE_ONDEMAND }); on(featureLayer, 'click', function (e) { var objectId, el; objectId = e.graphic.attributes[featureLayer.objectIdField]; featureLayer.queryAttachmentInfos(objectId, function (infos) { map.infoWindow.setTitle(objectId); el = document.createElement('img'); if (!!infos[0].url) { el.setAttribute('src', infos[0].url); map.infoWindow.setContent(el); map.infoWindow.show(e.screenPoint, map.getInfoWindowAnchor(e.screenPoint)); } }); }); map.addLayer(featureLayer); }); }); </script> </head> <body class="claro"> <div id="mapDiv"></div> </body> </html>
its displaying only image i need to dispaly something like this
http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=widget_popupfl
above example is for popup window but i need to do it for infotemplate
Veena,
Can you explain why you have a requirement to use infoTemplate? I have found that most of the time people just think that they need infoTemplate and really have no specific requirement.
i am using identifier so i am using info template
Robert,
Here is that sample updated to use the popups media infos, so that multiple images are supported and the images are more manageable size:
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<link rel="stylesheet" href="http://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.20/esri/css/esri.css">
<style>
html,
body,
#mapDiv {
padding: 0;
margin: 0;
height: 100%;
</style>
<script src="http://js.arcgis.com/3.20/"></script>
<script>
require([
"esri/dijit/PopupTemplate", "dojo/dom-construct", "dojo/on",
"dojo/_base/array", "dojo/domReady!"
], function(
PopupTemplate, domConstruct, on, arrayUtils
basemap: 'streets',
zoom: 17,
infoWindow: popup
on(map, 'load', function(_map_) {
featureLayer = new FeatureLayer('some url', {
on(featureLayer, 'click', function(e) {
var objectId, el;
var pminfos = [];
var popUpMediaInfo;
featureLayer.queryAttachmentInfos(objectId, function(infos) {
var popUpInfo = {
title: "Attachment images",
description: "",
showAttachments: false
arrayUtils.map(infos, function(info){
if (!!info.url) {
popUpMediaInfo = {};
popUpMediaInfo.type = 'image';
popUpMediaInfo.value = {};
popUpMediaInfo.value.sourceURL = info.url;
popUpMediaInfo.value.linkURL = info.url;
popUpMediaInfo.caption = info.name;
pminfos.push(popUpMediaInfo);
popUpInfo.mediaInfos = pminfos;
var pt = new PopupTemplate(popUpInfo);
e.graphic.setInfoTemplate(pt);
map.infoWindow.setFeatures([e.graphic]);
</script>
</head>
</body>
</html>
Thanks so much! That is pretty slick!
on(myLayer, 'click', function (e) {
map.graphics.clear();
var id;
var pminfosA = [];
id = e.graphic.attributes[artlayers.objectIdField];
artlayers.queryAttachmentInfos(id, function (infos) {
if (infos.length > 0) {
arrayUtils.map(infos, function (info) {
var popUpMediaInfo;
if (!!info.url) {
pminfosA.push(popUpMediaInfo);
var pt = new PopupTemplate({
title: "{FEATURE_NAME}",
showAttachments: false,
mediaInfos: (pminfosA)
else {
var pt2 = new PopupTemplate({
description: "no images available"
e.graphic.setInfoTemplate(pt2);
Above is some code that will show multiple photos. Also, How would i display a PDF in the pop that is an attachment?
