how to display photo or attachment in infotemplate
7363
10
02-04-2016 09:45 PM
veenahosur1
i need to display photos in info template.can any one tell me how to do it
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Veena,
I found the following sample on GitHub:
Add an attachment image to popup infoWindow for ArcGIS JavaScript API. · GitHub
Here it is an example of the code converted to AMD:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Sample Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.15/"></script>
    <script>
      var map, popup, featureLayer;
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Popup",
        "dojo/dom-construct","dojo/on",
        "dojo/domReady!"
        ], function (
            Map, FeatureLayer, Popup,
            domConstruct, on
            popup = new Popup(null, domConstruct.create('div'));
            map = new Map('mapDiv', {
                basemap: 'streets',
                center: [-74.0499, 40.0403],
                zoom: 17,
                infoWindow: popup
            on(map, 'load', function (_map_) {
                featureLayer = new FeatureLayer('http://services.arcgis.com/dlFJXQQtlWFB4qUk/arcgis/rest/services/ResidentialBuildings/FeatureServer/...', {
                    mode: FeatureLayer.MODE_ONDEMAND
                on(featureLayer, 'click', function (e) {
                    var objectId, el;
                    objectId = e.graphic.attributes[featureLayer.objectIdField];
                    featureLayer.queryAttachmentInfos(objectId, function (infos) {
                        map.infoWindow.setTitle(objectId);
                        el = document.createElement('img');
                        if (!!infos[0].url) {
                            el.setAttribute('src', infos[0].url);
                            map.infoWindow.setContent(el);
                            map.infoWindow.show(e.screenPoint, map.getInfoWindowAnchor(e.screenPoint));
                map.addLayer(featureLayer);
    </script>
  </head>
  <body class="claro">
    <div id="mapDiv"></div>
  </body>
</html>
veenahosur1
its displaying only image i need to dispaly something like this
http://developers.arcgis.com/javascript/sandbox/sandbox.html?sample=widget_popupfl
above example is for popup window but i need to do it for infotemplate
RobertScheitlin__GISP
Veena,
   Can you explain why you have a requirement to use infoTemplate? I have found that most of the time people just think that they need infoTemplate and really have no specific requirement.
veenahosur1
i am using identifier so i am using info template
RobertKirkwood
what would you use?
Robert,
   Here is that sample updated to use the popups media  infos, so that multiple images are supported and the images are more manageable size:
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
  <link rel="stylesheet" href="http://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.20/esri/css/esri.css">
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="http://js.arcgis.com/3.20/"></script>
  <script>
    require([
      "esri/dijit/PopupTemplate", "dojo/dom-construct", "dojo/on",
      "dojo/_base/array", "dojo/domReady!"
    ], function(
      PopupTemplate, domConstruct, on, arrayUtils
        basemap: 'streets',
        zoom: 17,
        infoWindow: popup
      on(map, 'load', function(_map_) {
        featureLayer = new FeatureLayer('some url', {
        on(featureLayer, 'click', function(e) {
          var objectId, el;
          var pminfos = [];
          var popUpMediaInfo;
          featureLayer.queryAttachmentInfos(objectId, function(infos) {
            var popUpInfo = {
              title: "Attachment images",
              description: "",
              showAttachments: false
            arrayUtils.map(infos, function(info){
              if (!!info.url) {
                popUpMediaInfo = {};
                popUpMediaInfo.type = 'image';
                popUpMediaInfo.value = {};
                popUpMediaInfo.value.sourceURL = info.url;
                popUpMediaInfo.value.linkURL = info.url;
                popUpMediaInfo.caption = info.name;
                pminfos.push(popUpMediaInfo);
            popUpInfo.mediaInfos = pminfos;
            var pt = new PopupTemplate(popUpInfo);
            e.graphic.setInfoTemplate(pt);
            map.infoWindow.setFeatures([e.graphic]);
  </script>
</head>
</body>
</html>
RobertKirkwood
Thanks so much! That is pretty slick!
RobertKirkwood
on(myLayer, 'click', function (e) {
                    map.graphics.clear();
                    var id;
                    var pminfosA = [];
                    id = e.graphic.attributes[artlayers.objectIdField];
                    artlayers.queryAttachmentInfos(id, function (infos) {
                        if (infos.length > 0) {
                            arrayUtils.map(infos, function (info) {
                                var popUpMediaInfo;
                                if (!!info.url) {
                                    pminfosA.push(popUpMediaInfo);
                            var pt = new PopupTemplate({
                                title: "{FEATURE_NAME}",
                                showAttachments: false,
                                mediaInfos: (pminfosA)
                        else {
                            var pt2 = new PopupTemplate({
                                description: "no images available"
                            e.graphic.setInfoTemplate(pt2);
RobertKirkwood
Above is some code that will show multiple photos. Also, How would i display a PDF in the pop that is an attachment?
