How to disable coordinate widget capture mode
1416
11-22-2023 03:06 PM
BradBarnell
When in "Capture" mode on the Coordinate Conversion widget and then removing the widget from the UI, how do you disable the widget from continuing to capture map click points?  I would like to change the mode back to "Live" mode without having to click the toggle button on the widget to disable it.  I know I can destroy the widget, but that is not ideal.
View.ui.remove(coordinate_conversion_widget)
Tags (1)
JoelBennett
MVP Regular Contributor
This appears to work:
View.ui.remove(coordinate_conversion_widget);
coordinate_conversion_widget.mode = "live";
JoelBennett
Noah-Sager
Can you explain your use case a bit more?
BradBarnell
Users forget to toggle the Capture mode off on the Coordinate widget and then they click a button to hide the Coordinate widget.  After that the click event on the map is stuck in capture coordinate location mode.
