How to create a renderer subject to the zoom level, LOD, or scale?
1712
08-22-2023 05:24 AM
ChungLam
I would like to have a ClassBreakRenderer that could remove the polygon outline when the zoom level/LOD/Scale is below a certain threshold. How can I do it?
I can only find the `ScaleDependentRenderer` in legacy documentation: https://developers.arcgis.com/javascript/3/jsapi/scaledependentrenderer-amd.html is the closest result; however, there is no such class available in the latest JS SDK.
Tags (1)
ChungLam
Thank you, with your information I managed to dig out a simple sample that serves the purpose 🙂
JoelBennett
MVP Regular Contributor
Unfortunately the ScaleDependentRenderer was not migrated from 3x to 4x.  In addition, unlike in 3.x, you cannot create custom renderer modules in 4.x applications.  Therefore, you'll have to approach this differently in 4.x.
Basically, a ScaleDependentRenderer was a collection of other renderers, one of which would become active at a given scale range.  Therefore, in a 4.x application, you'll need to (1) create that collection of other renderers manually, (2) watch the scale of the view, and when it changes, (3) determine which renderer from the collection your layer should be using.
There's also more information in this thread.
ChungLam
