How to convert ArcGIS Javascript Geometry Object to GeoJson
3988
03-19-2012 06:21 AM
SureshRajamani
How to convert ArcGIS Javascript Geometry Object to GeoJson?
nicogis
you try see http://odoe.net/blog/?p=187
http://esritogeo.herokuapp.com/
an alternative you can create a soe/gp and using data interoperability server extension that I remember convert in geojson 1.0.
ReneRubalcava
Esri Frequent Contributor
I should note too, that in the context of a standalone application, you don't really need to stringify the results of the conversion. That was done in the context of using the solution via REST.
nicogis
by Anonymous User
Not applicable
Sorry to tag onto this thread but you all seem like the right crowd to ask...Has anyone worked with Terraformer? I'm struggling with the JSON result of an ArcGIS REST API query and getting the GeoJSON using Terraformer.ArcGIS.parse(esriJson). Happy to provide code if anyone has thoughts. Thanks!
