How to change the pin location image in map
6214
12
06-03-2022 02:36 AM
NEERAJNASWA
Hello,
I want to know How can I change the pin location image in map? I want to give my custom image as shown in image
NEERAJNASWA
The code is now working, But I need help in removing the blue highlight color after clicking the pin image.I am sharing my code.
  var views = new MapView({
                    container: "viewDiv",
                    map: map,
                    center: [20,40],
                    zoom: 16,
                    popup: {
                        dockEnabled: true,
                        dockOptions: {
                          buttonEnabled: false,
                          breakpoint: false
                let centroidRenderer = {
                    type: "simple",
                    symbol: {
                      type: "picture-marker",
                     url: "images/Location-map.png",
                     width: "26",
                      height: "26"
                  let locationpin = new FeatureLayer({
                    url:
                     renderer: centroidRenderer,
                     popupTemplate : popupTemplate
                  var maps = new Map({
                    basemap: "dark-gray",
                    layers: [locationpin]
                //   var privateSchoolsPoly = new FeatureLayer({
                //     url:
                //     outFields: ["*"],
                //     opacity: 0.8,
                //     renderer: renderer,
                function getGraphics(response) {
                    view.graphics.removeAll();
                    if (response.results.length > 0) {
                      var graphic = response.results[0].graphic;
                      graphic.symbol = {
                                   // url: "images/Location-Red.png",
                                 width: "26",
                                  height: "26"
                      view.graphics.add(graphic);
                  view.when(function () {
                    view.whenLayerView(locationpin).then(function (lview) {
                      watchUtils.whenFalseOnce(lview, "updating", function () {
                        // Set up a click event handler and retrieve the screen x, y coordinates
                        view.on("click", function (evt) {
                          var screenPoint = {
                            x: evt.x,
                            y: evt.y
                          // the hitTest() checks to see if any graphics in the view
                          // intersect the given screen x, y coordinates
                          view.hitTest(screenPoint)
                            .then(function (response) {
                             // changeCursor(response);
                              getGraphics(response);
                  view.when(function() {
                    map.addMany([locationpin]);
JillianStanford
I'm not sure of the answer but you could try setting the highlight option property on the Map View
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#highlightOptio...
NEERAJNASWA
Thanks, the Highlight option worked as per the expectation.
