How to change basemap coordinates from Sketch feature to XY Coordinates
2339
01-15-2022 05:50 PM
RahmanNurhidayat
Hi everyone, I have a problem changing the coordinate type from the sketch feature to the XY coordinate type.
whenever i see result from draw coordinate type it stays basemap type.
code:
log:
please help me solve it.
UndralBatsukh
Hi there,
Yes sketch creates geometries with a spatial reference that matches the spatial reference of the view. If your basemap's spatial reference is Web Mercator (102100) then you can use webMercatorUtils.webMercatorToGeographic() method to project the geometry to geographic spatial reference.
You can do something like the following.
sketch.on("create", (event) => {
  if (event.state === "complete") {
    console.log("sketch geometry", event.graphic.geometry);
    const geographicGeom = webMercatorUtils.webMercatorToGeographic(event.graphic.geometry);
     console.log("geographic geometry", geographicGeom)
If your basemap's spatialReference is not WebMercator then you can use projection.project() method.
Hope this helps,
UndralBatsukh
Hi there,
Hope this helps,
RahmanNurhidayat
Thanks. Its Worked
Lazy
nice
