How to bundle @arcgis/core files in Angular build?
3937
05-05-2021 07:15 AM
ShaneBuscher1
I have a very simple Angular app that generates 171 build js files from @arcgis/core. Is there a way to combine these into a single js file that can be referenced in a single html script tag?
For some background I'm using Angular Elements to create a native web component from an Angular component containing an arcgis js map. When I drop that web component in a vanilla html page I get console errors about the missing 171 js files. I need to bundle up the 171 files into a singe one but somehow keep the references intact.
<!DOCTYPE html>
<html lang="en">
  <head>
    <meta charset="utf-8" />
    <title>ESRI Map</title>
    <base href="/" />
    <meta name="viewport" content="width=device-width, initial-scale=1" />
    <link rel="icon" type="image/x-icon" href="favicon.ico" />
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.19/esri/themes/light/main.css"
    <script src="main.js"></script>
    <script src="polyfills.js"></script>
    <script src="vendor.js"></script>
  </head>
  <body>
    <esri-map></esri-map>
    <script src="map-elements.js"></script>
  </body>
</html>
AndyGup
Hi @ShaneBuscher1 I haven't used Angular elements, but with a webpack build you have to include all the output bundle files from the Angular build - main,js is just the entry point. Here's a couple blog posts that talk about the ES modules: https://www.esri.com/arcgis-blog/products/js-api-arcgis/announcements/arcgis-api-for-javascript-work...  and https://www.esri.com/arcgis-blog/products/js-api-arcgis/mapping/javascript-just-works/
ShaneBuscher1
Going to partially answer my question. I ended up copying the 171 files to the root of the html app in addition to the @arcgis/core assets. This fixed all of the errors and was able to display the map web component. However, still looking for a cleaner way of bundling all the files to make deployments cleaner.
AndyGup
ShaneBuscher1
Thanks for the resources @AndyGup and quick response. What you describe makes sense with main.js being the entry point and webpack doing its thing to split up the files for optimization.
ReneRubalcava
Esri Frequent Contributor
I can add to this that I have tested a single file bundle. using webpack and you pretty much end up with a 7mb js file with tons of code you probably won't use at runtime.
