How to avoid the 'timeout exceeded' error when using esri javascript api 3.X?
8876
02-16-2018 01:18 AM
LeoDeng
   When using esri javascript api loading the basemap, errors appear indicating a timeout on the arcgis tile server with dev console open.
  Although this doesn't occur every time when loading the map, I still want to avoid the error. Please see the SS for details.
  Is there any way to fix the issue by coding?
  The version of esri javascript api is 3.18 built by ArcGIS API for JavaScript Web Optimizer.
  Leo
ChrisSmith7
Honored Contributor
Have you tried adjusting the default timeout on the request, e.g. esriConfig.defaults.io.timeout?
ChrisSmith7
Honored Contributor
LeoDeng
Thank you for your reply. I've tried this setting, it seems less error now. Maybe I should set more time. Currently, I set the value to 120000. (2 mins)
TarunMeher
Where to change this ?
LeoDeng
