How to addEventListener to a button in popup content of ArcGIS API for JS
3433
04-18-2022 10:29 AM
NoorMaria
I have created a custom popup with the popupTemplate function with ArcGIS JS API 4.x
And i add a button in popup content by html.
but i can not addEventListener to a button in popup.
here is the way i am try to do now: ((the full code is here:https://codepen.io/llllllllc/pen/mdpabGwmaterial))
  1. return html to create button in popup content
const popupTemplate = {
                // autocasts as new PopupTemplate()
                title: "Population in {NAME}",
                content: populationChange,
                layer.popupTemplate = popupTemplate;
                function populationChange(feature)
                    const div = document.createElement("div");
                    div.innerHTML =
                        "<input type='button' id='btn' value='CLICK'>";
                    return div;
  1. watch content change
view.popup.watch("content", (newValue, oldValue, propertyName, target) => {......});
3.querySelector("#btn") then addEventListener but it fail ,and console.log(btn) show btn is null
const btn = document.querySelector("#btn");
console.log(btn)
btn.addEventListener(
    "click",
    function () {
        lert("HELLO WORLD!");
   false
);a
ReneRubalcava
Esri Frequent Contributor
Here is a sample adding a button to the popup content.
https://codepen.io/odoe/pen/abEPGxR?editors=1000
You can either reuse the button you create, or be sure to remove the event listener if you don't
This is using the CustomContent of the PopupTemplate
https://developers.arcgis.com/javascript/latest/api-reference/esri-popup-content-CustomContent.html
sarahjones4
Along similar lines.
        function populationChange(feature) {
          const btn = document.createElement("button")
          btn.innerHTML = 'Click Me'
          btn.onclick = function(props) {
            alert('hello world.')
          return div.appendChild(btn)
