How to add Tooltip for each option of a select tag?
16936
07-11-2018 09:09 PM
AlifShaikh
I am working with ArcGIS JS API and the dijit.form.Select.
I have this below code.
var ddl = document.getElementById("stateSelect"),
arr = ["I just created new DropDown and added tooltip code.", "css", "java", "javascript", "php", "c++", "node.js", "ASP", "JSP", "SQL"];
for (var i = 0; i < arr.length; i++) {
var option = document.createElement("OPTION"),
txt = document.createTextNode(arr);
option.appendChild(txt);
option.setAttribute("label", arr);
option.setAttribute("value", '<div tooltip="Bar Tooltip" onmouseover="showTooltip(this)" onmouseout="hideTooltip(this)">Barrrrrrrrrrrrrrrrrrrrrrr</div>');
ddl.insertBefore(option, ddl.lastChild);
function showTooltip(el) {
dijit.showTooltip(el.getAttribute('tooltip'), el);
function hideTooltip(el) {
dijit.hideTooltip(el);
My question is how do I pass HTML tag in option.setAttribute and how to make the </div> value to be same as arr
RobertScheitlin__GISP
Alif,
  Here is a working sample.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Tooltip on Select Items</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.25/dijit/themes/claro/claro.css">
    <script src="https://js.arcgis.com/3.25/"></script>
    <script>
      require([
        "dojo/parser",
        "dijit/registry",
        "dijit/form/Select",
        "dojo/domReady!"
      ], function (parser, registry) {
          parser.parse();
          var ddl = registry.byId("stateSelect");
          var options = [];
          var arr = ["I just created new DropDown and added tooltip code.", "css", "java", "javascript", "php", "c++", "node.js", "ASP", "JSP", "SQL"];
            val = arr[i];
            var option = {
              value: val,
              label: '<span title="blah">' + val +  '</span>',
            options.push(option);
            if (i === 0) {
              options[i].selected = true;
          ddl.addOption(options);
    </script>
  </head>
  <body class="claro">
    <select id="stateSelect" data-dojo-type="dijit/form/Select">
  </body>
</html>
Alif,
<!DOCTYPE html>
<html>
  <head>
    <script>
      require([
        "dojo/parser",
        "dijit/registry",
        "dojo/domReady!"
          parser.parse();
          var options = [];
            val = arr[i];
            var option = {
              value: val,
            if (i === 0) {
    </script>
  </head>
  </body>
</html>
AlifShaikh
Hi Robert,
Thanks for the code.
However,the code displays tooltip for only the first item in the array (arr[0]) I want the tooltip to be added to every item in the array with its corresponding value.
label: '<span title="blah">' + val +  '</span>', // where the Title tag should be value of
the hovered item in the array
I have modified a bit see below.
 var option = {
              value: val,
              label: '<span onmouseover="showTooltip(this)" onmouseout="hideTooltip(this)">' + val +  '</span>',
But, I am not able to set the title attribute of the span to the value of the hoevered element in the list. Any help would be greatly appreciated.
Thanks
Alif,
   So just change line 27 in my sample to this and you are good to go.
label: '<span title="'+ val +'">' + val +  '</span>',
There is NO need whatsoever to have the mouseover and mouseout.
AlifShaikh
Hi Robert,
Thanks for the sample. that worked.
Regards,
Alif
