how to add a popup for image service, Javascript?
3233
6
11-12-2014 12:08 PM
MarceloOyuela
Hello understand how to add a popup for a feature layer, but not for a image service layer. The image contains attribute table.
Regards
TimWitt2
MarceloOyuela
Yea, like that
TimWitt2
Check out the attached code. You will need an identify task.
MarceloOyuela
But my service it's a image service, regards
MarceloOyuela
i want to add a popup to this:
<script>
      var map;
      require([
        "esri/map", "esri/layers/ArcGISImageServiceLayer",
        "esri/layers/ImageServiceParameters", "dojo/parser", "dojo/domReady!"
      ], function(
        Map, ArcGISImageServiceLayer,
        ImageServiceParameters, parser
        parser.parse();
        map = new Map("map", {
          basemap: "topo",
          center: [-71.2, 19
          zoom: 9
        var params = new ImageServiceParameters();
        params.noData = 0;
        var imageServiceLayer = new ArcGISImageServiceLayer("http://portalgis.cathalac.org/arcgis/rest/services/Yaque/combine_wm/ImageServer", {
          imageServiceParameters: params,
          opacity: 0.75
        map.addLayer(imageServiceLayer);
    </script>
LuisPedraz
Hi Marcelo,
you need to use esri.task.ImageServiceIdentifyTask. More info in the api documentation:
imageserviceidentifytask | API Reference | ArcGIS API for JavaScript
Good luck!
