Attribute Inspector Syntax
1798
12-18-2014 07:55 AM
williamcarr
I'm attempting to expand on a previous app that adds a point to the map based on a users mobile location. I got that part working fine, the issue is that now I need it to open the attribute inspector after clicking a button. I can confirm that the point is being added to my server, but the attribute inspector isn't displaying. I know this is due to the sample code from Using the attribute inspector | ArcGIS API for JavaScript using a different event, I'm just unsure how to adjust the variables in the functions.
Any help is greatly appreciated.
Sample:
   function initSelectToolbar(evt) {
          var petroFieldsFL = evt.layers[0].layer;
          var selectQuery = new Query();
          map.on("click", function(evt) {
            selectQuery.geometry = evt.mapPoint;
            petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
                //store the current feature
                updateFeature = features[0];
                map.infoWindow.setTitle(features[0].getLayer().name);
                map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
What I got:
      //get a reference to the element
var myBtnn = document.getElementById('myBtnn');
//add event listener
myBtnn.addEventListener('click',
       function docking(){
  console.log("bwahhhhh1");
// using static point for testing purposes
          var pt = new Point( -84.960736,32.277353);
          if ( !graphic ) {
            addGraphic(pt);
          } else { // move the graphic if it already exists
            graphic.setGeometry(pt);
        var geometry;
        function addGraphic(pt){
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CIRCLE,
            12);
          graphic = new Graphic(pt, symbol);
          map.graphics.add(graphic);
        console.log("bwahhhhh2");
          new esri.geometry.Point(pt, map.spatialReference);
          var newFeature = new esri.Graphic(geometry, null,null);
featureLayer.applyEdits([newFeature], null, null, function () {}, function() {});
console.log("bwahhhhh22");
            var layerInfoss = [
             { 'featureLayer': featureLayer,
            'showAttachments': false,
            'isEditable': true}
                  var attInspector = new AttributeInspector({
            layerInfos:layerInfoss
          }, domConstruct.create("div"));
          console.log("tell me it works ricky!!");
          //add a save button next to the delete button
          var saveButton = new Button({ label: "Save", "class": "saveButton"});
          domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
          saveButton.on("click", function(pt){
          updateFeature = featureLayer;
            updateFeature.getLayer().applyEdits(null, [updateFeature], null);
               console.log("tell me it works julian!!");
          attInspector.on("attribute-change", function(pt) {
            //store the updates to apply when the save button is clicked
            updateFeature.attributes[fieldName] = fieldValue;
               console.log("tell me it works bubbles!!");
          attInspector.on("next", function(pt) {
               console.log("tell me it works corey!!");
            console.log("Next " + updateFeature.attributes.objectid);
          attInspector.on("delete", function(pt){
            newFeature.getLayer().applyEdits(null,null,[featureLayer]);
               console.log("tell me it works trevor!!");
            map.infoWindow.hide();
          map.infoWindow.setContent(attInspector.domNode);
          map.infoWindow.resize(350, 240);
             console.log("tell me it works randy!!");
Tags (1)
