How long would I have to wait for web appbuilder SDK that is competible with new Arcgis online?
2207
06-29-2017 11:27 PM
bobpark
I am getting "The theme used in the app is newer version". From what I read from Geonet forum, the only solution is to wait for newer version of web appbuilder. I do know a way to work around it but I am just curious to know when will the newer web appbuilder will be released.
RebeccaStrauch__GISP
Typically the developer edition is released 4-6 weeks after the online version. The Portal version is after that.
With the UC right around the corner, sometimes timing changes some as they try to push versions (i.e. AGOL and 10.5.1) out before the UC so people can start playing with it before they go.
dlaw-esristaff
bobpark
Hi Rebecca,
Thanks for the reply. very helpful Info!
DerekLaw
Esri Esteemed Contributor
Hi Bob,
As Rebecca Strauch, GISP said, the next update to Web AppBuilder Developer Edition v2.5 is planned to be release at the end of July/early August timeframe.
Hope this helps,
bobpark
Hi Derek,
Also very helpful thank you for your info.
