How do you remove the maximize/dock in the top right button from the default popup?
5541
05-24-2016 06:23 AM
JustinJackson
Is there an option to turn it off?  Would I have to make my own popup class?
KristianEkenes
There's actually an easier way to do this with JavaScript. I recommend not overriding it with CSS as this can cause some issues when upgrading to future versions.
The popup has a dockOptions property which has an option to disable this button: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Popup.html#dockOptions
Simply do the following:
view.popup.dockOptions.buttonEnabled = false;
Or
var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-73.950, 40.702],
        zoom: 11,
        popup: {
          dockOptions: {
            buttonEnabled: false
When constructing your view.
RobertScheitlin__GISP
Justin,
  Just add some css to remove that from the popup
.esriPopup .titleButton.maximize {
        display: none;
KristianEkenes
Or
        map: map,
        zoom: 11,
        popup: {
          dockOptions: {
