How do I return a list of fields from FeatureLayer?
4701
7
04-28-2015 03:12 PM
MStayner
Seems like this should be simple, but I'm stumped.  I want to modify this sample to output to the console the list of fields for the loaded FeatureLayer.  See below.  The only modification I made was to add line 65: console.log(states);
That works fine, and shows there is attribute called "fields" for the layer states.  However, on the next line when I try  log console.log(states.fields); it says it is undefined.  Why?  And the bigger question, how do I get the list of fields?
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
    <title></title>
    <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.13/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
    <script src="//js.arcgis.com/3.13/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/geometry/Extent",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/TextSymbol",
        "esri/renderers/SimpleRenderer",
        "esri/layers/LabelLayer",
        "esri/Color",
        "dojo/domReady!"
      ], function(
        Map, Extent, FeatureLayer,
        SimpleLineSymbol, SimpleFillSymbol, TextSymbol, SimpleRenderer,
        LabelLayer,
        Color
        // load the map centered on the United States
        var bbox = new Extent({"xmin": -1940058, "ymin": -814715, "xmax": 1683105, "ymax": 1446096, "spatialReference": {"wkid": 102003}});
        map = new Map("map", {
          extent: bbox
        var labelField = "STATE_NAME";
        // create a renderer for the states layer to override default symbology
        var statesColor = new Color("#666");
        var statesLine = new SimpleLineSymbol("solid", statesColor, 1.5);
        var statesSymbol = new SimpleFillSymbol("solid", statesLine, null);
        var statesRenderer = new SimpleRenderer(statesSymbol);
        // create a feature layer to show country boundaries
        var statesUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3";
        var states = new FeatureLayer(statesUrl, {
          outFields: [labelField]
        states.setRenderer(statesRenderer);
        map.addLayer(states);
        // create a text symbol to define the style of labels
        var statesLabel = new TextSymbol().setColor(statesColor);
        statesLabel.font.setSize("14pt");
        statesLabel.font.setFamily("arial");
        var statesLabelRenderer = new SimpleRenderer(statesLabel);
        var labels = new LabelLayer({ id: "labels" });
        // tell the label layer to label the countries feature layer
        // using the field named "admin"
        labels.addFeatureLayer(states, statesLabelRenderer, "{" + labelField + "}");
        // add the label layer to the map
        map.addLayer(labels);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
KellyHutchins
Esri Frequent Contributor
Here's an example that shows how to output the field info and/or the field name to the console.
        states.on("load", function(){
          for(i = 0; i < states.fields.length; i++){
            //write out field info
            console.log(dojoJson.toJson(states.fields));
            //write out just field name
            console.log(states.fields.name);
In order to format the field info in a way that's easier for you to copy/paste I use the toJson method which means you'll need to require the dojo/_base/json module.
      require([
        "esri/map",
        "esri/Color",
        "dojo/_base/json",
        "dojo/domReady!"
      ], function(
        LabelLayer,
        Color, dojoJson
BlakeTerhune
MVP Regular Contributor
Looks like you accidentally posted this in the GeoNet Help section. It should probably be in ArcGIS API for JavaScript
MStayner
Oops.  Is there a way I can change where this is posted, or should I just create a new post over there?
KenBuja
I've moved it for you.
PaulCrickard
Paste a copt of the console.log in here. I bet it has to do with states[0].fields or something in the object.
MStayner
I struggling copying the Object out of my console.  Below is what I get when I right-click the Object in the Chrome browser and copy it.  Is there a better way?
yField":"STATE_NAME","typeIdField":null,"fields":[{"name":"OBJECTID","type":"esriFieldTypeOID","alias":"OBJECTID","domain":null},{"name":"Shape","type":"esriFieldTypeGeometry","alias":"Shape","domain":null},{"name":"STATE_NAME","type":"esriFieldTypeString","alias":"STATE_NAME","length":25,"domain":null},{"name":"STATE_FIPS","type":"esriFieldTypeString","alias":"STATE_FIPS","length":2,"domain":null},{"name":"SUB_REGION","type":"esriFieldTypeString","alias":"SUB_REGION","length":20,"domain":null},{"name":"STATE_ABBR","type":"esriFieldTypeString","alias":"STATE_ABBR","length":2,"domain":null},{"name":"POP2000","type":"esriFieldTypeInteger","alias":"POP2000","domain":null},{"name":"POP2007","type":"esriFieldTypeInteger","alias":"POP2007","domain":null},{"name":"POP00_SQMI","type":"esriFieldTypeDouble","alias":"POP00_SQMI","domain":null},{"name":"POP07_SQMI","type":"esriFieldTypeDouble","alias":"POP07_SQMI","domain":null},{"name":"WHITE","type":"esriFieldTypeInteger","alias":"WHITE","domain":null},{"name":"BLACK","type":"esriFieldTypeInteger","alias":"BLACK","domain":null},{"name":"AMERI_ES","type":"esriFieldTypeInteger","alias":"AMERI_ES","domain":null},{"name":"ASIAN","type":"esriFieldTypeInteger","alias":"ASIAN","domain":null},{"name":"HAWN_PI","type":"esriFieldTypeInteger","alias":"HAWN_PI","domain":null},{"name":"OTHER","type":"esriFieldTypeInteger","alias":"OTHER","domain":null},{"name":"MULT_RACE","type":"esriFieldTypeInteger","alias":"MULT_RACE","domain":null},{"name":"HISPANIC","type":"esriFieldTypeInteger","alias":"HISPANIC","domain":null},{"name":"MALES","type":"esriFieldTypeInteger","alias":"MALES","domain":null},{"name":"FEMALES","type":"esriFieldTypeInteger","alias":"FEMALES","domain":null},{"name":"AGE_UNDER5","type":"esriFieldTypeInteger","alias":"AGE_UNDER5","domain":null},{"name":"AGE_5_17","type":"esriFieldTypeInteger","alias":"AGE_5_17","domain":null},{"name":"AGE_18_21","type":"esriFieldTypeInteger","alias":"AGE_18_21","domain":null},{"name":"AGE_22_29","type":"esriFieldTypeInteger","alias":"AGE_22_29","domain":null},{"name":"AGE_30_39","type":"esriFieldTypeInteger","alias":"AGE_30_39","domain":null},{"name":"AGE_40_49","type":"esriFieldTypeInteger","alias":"AGE_40_49","domain":null},{"name":"AGE_50_64","type":"esriFieldTypeInteger","alias":"AGE_50_64","domain":null},{"name":"AGE_65_UP","type":"esriFieldTypeInteger","alias":"AGE_65_UP","domain":null},{"name":"MED_AGE","type":"esriFieldTypeDouble","alias":"MED_AGE","domain":null},{"name":"MED_AGE_M","type":"esriFieldTypeDouble","alias":"MED_AGE_M","domain":null},{"name":"MED_AGE_F","type":"esriFieldTypeDouble","alias":"MED_AGE_F","domain":null},{"name":"HOUSEHOLDS","type":"esriFieldTypeInteger","alias":"HOUSEHOLDS","domain":null},{"name":"AVE_HH_SZ","type":"esriFieldTypeDouble","alias":"AVE_HH_SZ","domain":null},{"name":"HSEHLD_1_M","type":"esriFieldTypeInteger","alias":"HSEHLD_1_M","domain":null},{"name":"HSEHLD_1_F","type":"esriFieldTypeInteger","alias":"HSEHLD_1_F","domain":null},{"name":"MARHH_CHD","type":"esriFieldTypeInteger","alias":"MARHH_CHD","domain":null},{"name":"MARHH_NO_C","type":"esriFieldTypeInteger","alias":"MARHH_NO_C","domain":null},{"name":"MHH_CHILD","type":"esriFieldTypeInteger","alias":"MHH_CHILD","domain":null},{"name":"FHH_CHILD","type":"esriFieldTypeInteger","alias":"FHH_CHILD","domain":null},{"name":"FAMILIES","type":"esriFieldTypeInteger","alias":"FAMILIES","domain":null},{"name":"AVE_FAM_SZ","type":"esriFieldTypeDouble","alias":"AVE_FAM_SZ","domain":null},{"name":"HSE_UNITS","type":"esriFieldTypeInteger","alias":"HSE_UNITS","domain":null},{"name":"VACANT","type":"esriFieldTypeInteger","alias":"VACANT","domain":null},{"name":"OWNER_OCC","type":"esriFieldTypeInteger","alias":"OWNER_OCC","domain":null},{"name":"RENTER_OCC","type":"esriFieldTypeInteger","alias":"RENTER_OCC","domain":null},{"name":"NO_FARMS97","type":"esriFieldTypeDouble","alias":"NO_FARMS97","domain":null},{"name":"AVG_SIZE97","type":"esriFieldTypeDouble","alias":"AVG_SIZE97","domain":null},{"name":"CROP_ACR97","type":"esriFieldTypeDouble","alias":"CROP_ACR97","domain":null},{"name":"AVG_SALE97","type":"esriFieldTypeDouble","alias":"AVG_SALE97","domain":null},{"name":"SQMI","type":"esriFieldTypeInteger","alias":"SQMI","domain":null},{"name":"Shape_Length","type":"esriFieldTypeDouble","alias":"Shape_Length","domain":null},{"name":"Shape_Area","type":"esriFieldTypeDouble","alias":"Shape_Area","domain":null}],"relationships":[],"canModifyLayer":true,"canScaleSymbols":false,"hasLabels":false,"capabilities":"Data,Map,Query","maxRecordCount":1000,"supportsStatistics":true,"supportsAdvancedQueries":true,"supportedQueryFormats":"JSON, AMF","ownershipBasedAccessControlForFeatures":{"allowOthersToQuery":true},"useStandardizedQueries":true,"advancedQueryCapabilities":{"useStandardizedQueries":true,"supportsStatistics":true,"supportsOrderBy":true,"supportsDistinct":true,"supportsPagination":false,"supportsTrueCurve":true}}"_loadCallback: undefined_lyrZEHandle: Object_map: Object_mapTimeExtent: null_maxOffset: 5088_mode: Object_mouseEvents: true_newFeatures: Array[0]_nextId: 0_onExtentChangeHandler_connect: Object_onPanEndHandler_connect: Object_onPanHandler_connect: Object_onPanStartHandler_connect: null_onZoomStartHandler_connect: Object_onclick_connect: Object_ondblclick_connect: Object_onmousedown_connect: Object_onmousemove_connect: Object_onmouseout_connect: Object_onmouseover_connect: Object_onmouseup_connect: Object_optEditable: undefined_orderBy: null_outFields: Array[1]_params: Object_plugins: Object_processEvent: function (){return f.apply(a,arguments||[])}_refresh: function (){return f.apply(a,arguments||[])}_rendererFields: Array[0]_resized: false_resumedOnce: true_rndForScale: undefined_selectHandler: function (){return f.apply(a,arguments||[])}_selectedFeatures: Object_selectedFeaturesArr: Array[0]_setMap: function (b){var c=e.apply(this,_srInfo: undefined_task: Object_tileHeight: 512_tileWidth: 512_timeConnect: null_trackIdField: undefined_ulid: 0_url: Object_usePatch: true_wakeTimer: null_wrap: false_zoomConnect: ObjectadvancedQueryCapabilities: ObjectallowGeometryUpdates: trueattributionDataUrl: ""canModifyLayer: truecanScaleSymbols: falsecapabilities: "Data,Map,Query"className: undefinedcopyright: "US Bureau of the Census: http://www.census.gov"credential: undefinedcurrentMode: 1dataAttributes: undefineddefaultDefinitionExpression: undefineddefaultVisibility: truedescription: "This service presents various population statistics from Census 2000, including total population, population density, racial counts, and more. The map service presents statistics at the state, county, block group, and block point levels.↵"disableMouseEvents: function (){return f.apply(a,arguments||[])}displayField: "STATE_NAME"editFieldsInfo: undefinededitSummaryCallback: undefinedenableMouseEvents: function (){return f.apply(a,arguments||[])}fields: Array[52]0: Object1: Object2: Object3: Object4: Object5: Object6: Object7: Object8: Object9: Object10: Object11: Object12: Object13: Object14: Object15: Object16: Object17: Object18: Object19: Object20: Object21: Object22: Object23: Object24: Object25: Object26: Object27: Object28: Object29: Object30: Object31: Object32: Object33: Object34: Object35: Object36: Object37: Object38: Object39: Object40: Object41: Object42: Object43: Object44: Object45: Object46: Object47: Object48: Object49: Object50: Object51: Objectlength: 52__proto__: Array[0]fullExtent: ObjectgdbVersion: undefinedgeneralizeForScale: 4000geometryType: "esriGeometryPolygon"globalIdField: undefinedgraphics: Array[49]hasAttachments: falsehasAttributionData: falsehasLabels: falsehtmlPopupType: "esriServerHTMLPopupTypeNone"i18n: aid: "states"indexedFields: undefinedinfoTemplate: undefinedinitialExtent: ObjectisDataVersioned: undefinedlatticeTiling: undefinedlayerId: 3loaded: truemaxPointCountForAuto: 4000maxRecordCount: 1000maxRecordCountForAuto: 2000maxVertexCountForAuto: 250000mode: 1multipatchOption: undefinedname: "states"normalization: trueobjectIdField: "OBJECTID"onEditsComplete: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onError: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onGraphicNodeAdd: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onLabelingInfoChange: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onLoad: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onResume: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onShowLabelsChange: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onSuspend: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||onUpdateEnd: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||ontime-extent-change: function (){for(var a=p,b=arguments,c=h.before;c;)b=c.advice.apply(this,b)||orderByFields: undefinedownershipBasedAccessControlForFeatures: Objectquantize: undefinedqueryPagination: falserefresh: function (){return f.apply(a,arguments||[])}refreshInterval: 0relationships: Array[0]renderer: ObjectshowLabels: truesource: undefinedspatialReference: Objectstatistics: undefinedstyling: truesupportsAdvancedQueries: truesupportsAttachmentsByUploadId: undefinedsupportsCalculate: undefinedsupportsCoordinatesQuantization: undefinedsupportsRollbackOnFailure: undefinedsupportsRollbackOnFailureParameter: undefinedsupportsStatistics: truesuspended: falsesyncCanReturnChanges: undefinedtemplates: Array[0]type: "Feature Layer"typeIdField: nulltypes: Array[0]updating: falseurl: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3"useMapTime: trueuserId: undefineduserIsAdmin: undefinedversion: 10.3visibilityField: undefinedvisibleAtMapScale: true__proto__: Object
KellyHutchins
      require([
        "esri/map",
        "esri/Color",
        "dojo/_base/json",
        "dojo/domReady!"
      ], function(
        LabelLayer,
        Color, dojoJson
MStayner
Perfect!  Thanks!
After looking at your code it appears the reason mine wasn't working was because the layers wasn't loaded yet.
Nice trick with the .toJson.  That is really handy!
