How do I make a graphics layer appear above others
1083
07-04-2023 05:39 PM
CalvinLe360
Hi, I'm looking to find out how to make a graphics layer appear above others after adding to map.
Let's say that I have two layers, each containing a circle at the same location and size, with the only difference being colour. The first layer will be hidden by the second, but at some point I want the first layer to hide the second instead.
// layerA appears over layerB because layerB is added earlier
const layerB = new GraphicsLayer();
const layerA = new GraphicsLayer();
map.layers.add(layerB);
map.layers.add(layerA);
// graphic stuff
const geometry = new Circle({
    center: {
        x: 0,
        y: 0,
    radius: 100,
    radiusUnit: 'meters',
const symbolA = new SimpleFillSymbol({
    color: [0, 0, 0, 1],
    style: 'solid'
    outline: {
        color: [0, 0, 0, 0],
const symbolB = symbolA.clone();
symbolB.g = 255;
layerA.add(new Graphic({
    geometry: geometry,
    symbol: symbolA,
layerB.add(new Graphic({
    geometry: geometry,
    symbol: symbolB,
// TODO: Make layerB appear over layerA
 Code might not be correct, but I wanted to lay out the form of the problem. If layerB gets put over layerA, then a green circle should appear instead of the black circle. How can I do this?
CalvinLe360
I sorted the layers on the map and it did what I wanted to do.
CalvinLe360
