How do I get individual values back from FeatureLayers on a click event?
8018
15
04-28-2015 10:31 AM
ChrisSergent
I want to be able to get individual values to populate this application: http://maps.decaturil.gov Currently when I click on a point on the map, its displays this:
How would I get just the value of the field OBJECTID for example?
ChrisSergent
I just have the click event. Here is the full code: https://github.com/csergent45/streetSigns/blob/master/app/main.js
and here is an excerpt:
app.citizenRequestLayer = new FeatureLayer(config.citizenRequestLayerUrl, {
            mode: FeatureLayer.MODE_ONEDEMAND,
            //infoTemplate: new InfoTemplate(config.infoTemplate),
            outFields: ["*"]
        app.map.addLayer(app.citizenRequestLayer);
        app.citizenRequestLayer.on("click", function (evt) {
          myObject = evt.graphic.attributes.OBJECTID;
KenBuja
MVP Esteemed Contributor
You defined "myobject" (line 89) but attempt to use "myObject"
TimWitt2
Or you can create a infotemplate for each layer if you want to make your popups look different.
Custom info window | ArcGIS API for JavaScript
ChrisSmith7
Honored Contributor
Here's an example of using a custom template:
var serviceUrl = "https://myserviceurl.com/arcgis/rest/services/etc ...";
var outFields = ["OBJECTID", "FIELD1", "FIELD2", "FIELD3"];
var content = "<tr>" + $("#ff_formVal").val() + ": <td>{FIELD3}</td></tr>"
var infoTemplate = new esri.InfoTemplate("{FIELD3}", content);
var fl = new FeatureLayer(serviceUrl, {
     mode: FeatureLayer.MODE_ONDEMAND,
     outFields: outFields,
     infoTemplate: infoTemplate,
     wkid: 102100
I made some code mods after pasting, so hopefully I didn't foobar something (updates not tested)!
NicholasHaney
Chris, I took a look at your code on GitHub. You declare the variable myobject on line 89 but then try to use the variable myObject on line 137. Variables are case sensitive in Javascript. Change the variable on line 137 to myobject and it should work.
ChrisSergent
Yea Nicholas Haney​ and Ken Buja​, I feel like an idiot. I know that JavaScript is case sensitive. Should've checked my case when I received those errors. Thanks for getting me back on track. And this is my easy question.
