How can I get click event Of esri.toolbars.Draw
2448
08-06-2014 07:33 PM
xiaoyunnsongb
1111.jpgHello every superiors:
      Now I have a question to   consult.
code A :
        var measureLengthToolbar = new esri.toolbars.Draw(map);
         measureLengthToolbar.activate(esri.toolbars.Draw.POLYLINE);
I know the end of  the event is
      code B:
                  dojo.connect(measureLengthToolbar, "onDrawEnd", function(geometry) {
            this  is the double click event .
when I  draw  the line  of  center ,I need single click, because  I need  to deal songthing when single click ,how can I draw the code like  code B,thanks very much.
OwenEarley
You could create a variable to check if the draw toolbar is active:
var isDrawing = false;
When you activate the draw toolbar update this variable to true:
tb.activate(tool);
isDrawing = true;
When you deactivate the draw toolbar update this variable to false:
tb.deactivate();
isDrawing = false;
Now you can use the map click event:
map.on("click", function(evt){
    // Check if user is drawing
    if (isDrawing) {
        // Add your code here...
I have created a working example on JS Bin: Draw Toolbar - map click event
The example prints information to the console log:
Hope this helps,
Owen
Spatial XP
OwenEarley
tb.activate(tool);
isDrawing = true;
tb.deactivate();
isDrawing = false;
    if (isDrawing) {
Hope this helps,
Owen
Spatial XP
xiaoyunnsongb
Dear oearley
     Thanks very much, wish you happy every day.
