hitTest() and PictureMarkerSymbol
992
05-10-2022 01:43 AM
snlasystem
Is it possible to get hitTest to also trigger on the PictureMarkerSymbol representing the graphic (not just the geometry)?
(view in My Videos)
An example shoving that the hover effect only triggers when the pointer is halfway through the icon.
ReneRubalcava
Esri Frequent Contributor
This is updated in our "next" version of the API, so it will be 4.24
@UndralBatsukh put together a sample here https://codepen.io/U_B_U/pen/abEMrzq?editors=1000
JoelBennett
MVP Regular Contributor
Note, this is only an issue when using (1) PictureMarkerSymbols with offsets, and (2) version 4.23 of the API.  It works fine in 4.22.  See also this post.
