Hide empty field in Popup
3737
7
03-16-2022 01:53 AM
Vakhtang_Zubiashvili
Hi all,
I am trying to hide empty field in Popup, i used ArcadeExpression:
IIF (IsEmpty($feature.Location), "", "block");
and jQuery:
$('table.esri-widget__table tr').each(function(){
            if($(this).children('td:empty').length === $(this).children('td').length){
              $(this).remove(); // or $(this).hide();
 but none of them works.
How can i hide fields "tr" in popup table? Any new idea?
Thanks
JayantaPoddar
Is "tr" the fieldname?
In Arcade, try
IIF (IsEmpty($feature["tr"]), "None", "block");
 Hide Field in Pop-up Using Arcade - Esri Community
Think Location
hi,
no, "tr" is a table raw. I changed
but does not work.
BlakeTerhune
Either your field value is not empty (maybe a space or something) or you're not adding the expression to the display property of the html style of the element. See step 8 in this guide:
hi,
so, i add expression like this:
  spopupTemplate = {
            content: [{
              type: "fields", // Autocasts as new FieldsContent()
              // Autocasts as new FieldInfo[]
              fieldInfos: [{
                fieldName: "expression/ნიშნული"
                fieldName: "expression/ჩაღრმავება"
                fieldName: "expression/წყლის დონე"
            // autocasts to ExpressionInfo class
            expressionInfos: [{
              title: "ნიშნული",
              expression: "IIF (IsEmpty($feature.Location), '', 'block');"
              title: "ჩაღრმავება",
              expression: "$feature.CaRrmaveba"
              title: "წყლის დონე",
              expression: "$feature.wylis_done"
Kishore
@Vakhtang_Zubiashvili
Try following:
expressionInfos: [{
              title: "ნიშნული",
              expression: "IIF (IsEmpty($feature.Location), 'None', 'inline');"
Regards,
Kishore
Thanks kishore,
but look what result i get:
it sets values, it does not hides empty value row 😞
SumitZarkarCT
Please check how you have configured the POP-UP it will work in case of custom popups only and if you have edited the html. Please check if you have followed step 6-8 correctly from the link
If possible please share the popup configuration
