3287
07-25-2016 10:22 AM
SoniaUguna_Urgilés
I am developing a geographic web with api js and want to place in the table of contents legend with an option to turn on and off , I use the legend function, but do not have the expected result. Can somebody help me.
RobertScheitlin__GISP
Sonia,
  You can use the LayerList dijit in the JS API:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Layer List Dijit</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
<style>
html, body, .container, #map {
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
    font-family: "Open Sans";
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
  background-color: #fff;
.esriLayerList .esriList{
    border-top:none;
.esriLayerList .esriTitle {
  border-bottom:none;
.esriLayerList .esriList ul{
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="https://js.arcgis.com/3.17/"></script>
<script>
require([
    "esri/arcgis/utils",
    "esri/dijit/LayerList",
    "dijit/layout/BorderContainer",
    "dijit/layout/ContentPane",
    "dojo/domReady!"
], function(
    arcgisUtils,
    LayerList
    //Create a map based on an ArcGIS Online web map id
    arcgisUtils.createMap("f63fed3f87fc488489e27c026fa5d434", "map").then(function(response){
        var myWidget = new LayerList({
           map: response.map,
           layers: arcgisUtils.getLayerList(response),
           showLegend: true
        },"layerList");
        myWidget.startup();
</script>
</head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'headline',gutters:false">
<div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
    <div id="layerList"></div>
</div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
Sonia,
<!DOCTYPE html>
<html>
<head>
<style>
    height:100%;
    width:100%;
    margin:0;
    padding:0;
    margin:0;
#map {
    padding:0;
#layerListPane{
    width:25%;
.esriLayer{
    border-top:none;
  border-bottom:none;
</style>
<script>
require([
    "dojo/domReady!"
], function(
    arcgisUtils,
    LayerList
           map: response.map,
           showLegend: true
        },"layerList");
        myWidget.startup();
</script>
</head>
</div>
</div>
</body>
</html>
SoniaUguna_Urgilés
Thank you, Robert Scheitlin and Rickey Fite.
I use LayerList, and table of content of layers are visibled, but don´t understad, why the layer are disabled and can´t turn on and turn off.  What am I doing wrong?... .... The code used is:
      map = new Map("map", {
            basemap: "streets",
            center: [-79, -2.89],
            zoom: 12
        layer_fugas = new ArcGISDynamicMapServiceLayer("http://geoportal.etapa.net.ec/arcgis/rest/services/SOAS/Servicio_Fugas/MapServer", {
            "showAttribution": true,
            "id": "codfuga",
        sectores = new ArcGISDynamicMapServiceLayer("http://geoportal.etapa.net.ec/arcgis/rest/services/SOAS/Sectores/MapServer", {
            "opacity": 0.30
        cartografia = new ArcGISDynamicMapServiceLayer("http://geoportal.etapa.net.ec/arcgis/rest/services/EMPRESA/Mapa_base/MapServer", {
        map.on("load", function () {
            busca_fuga(recuperafuga());
            map.infoWindow.resize(150,80);
        map.addLayers([layer_fugas, sectores, cartografia]);
        map.on ('layer-add-result', function(evt){
            map: map,
            showLegend: true,
            layers: [
                layer: cartografia,
                showSubLayers: true,
                showLegend: true,
                showOpacitySlider: true,
                visibility: true,
                layer: sectores,
                showLegend: true,
                visibility: true,
                layer: layer_fugas,
                showSubLayers: false,
                showLegend: true,
                visibility: true,
         },"legend");
        myWidget.startup();
Excuseme, somebody help me???.... Thanks....
Sonia,
  You are using map.addLayers([layer_fugas, sectores, cartografia]);
so the event that you need to listen for is map.on ('layers-add-result', function(evt){
not
SoniaUguna_Urgilés
Thanks Robert
I am very grateful with you
