Hello all,
2675
02-15-2016 09:46 PM
bharathreddy
i would like to select distance in textbox and buffer with query in arcgis javascript iam using arcgis 10.1 post the code if anybody have
bharathreddy
Thank u I have solved it
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Select with feature layer</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
     <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body, {
        padding:0;
        margin:0;
        height:100%;
      #messages{
        position:absolute;
        top:10px;
        right:20px;
        padding: 6px;
        background-color: #ccc;
        border-radius: 4px;
        border: solid 1px #333;
        z-index:99;
        max-width: 150px;
       html, body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow:hidden;
    #leftPane{
      color:#000;
      width:250px;
      padding-bottom:15px;
    #map{
      padding:0;
    .details{
      font-size:14px;
      font-weight:600;
      padding-bottom:20px;
    .ddl
    {font-family:Verdana;
     font-size:11px;
     color:#666666;
     font-weight:normal;
     height:20px;
     width:100px;
    .inputtxtbox
     font-size:11px;
     color:#666666;
     font-weight:normal;
     height:18px;
     width:60px;
    </style>
    <script>        var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
    <script>
        dojo.require("esri.map");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        dojo.require("esri.tasks.query");
        dojo.require("esri.tasks.geometry");
        dojo.require("esri.layers.FeatureLayer");
        var map,tb;
        function init() {
            //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
            //If this null or not available the buffer operation will not work.  Otherwise it will do a http post to the proxy.
            esri.config.defaults.io.proxyUrl = "/proxy";
            map = new esri.Map("mapDiv", {
              //  basemap: "streets",
                center: [-95.249, 38.954],
                zoom: 14
           // dojo.connect(map, "onLoad", initToolbar);
            landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("your url", { opacity: 5.55 });
            map.addLayer(landBaseLayer);
            //add the census block points in selection mode. Note that an info template has been defined so when
            //selected features are clicked a popup window will appear displaying the content defined in the info template.
            var featureLayer = new esri.layers.FeatureLayer("feature layer url@", {
            //define a selection symbol that will be used to draw the selected census block points within the buffer polygon
//            var symbol = new esri.symbol.SimpleMarkerSymbol(
//          esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE, 12,
//          new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_NULL,
//          new dojo.Color([247, 34, 101, 0.9]), 1),
//          new dojo.Color([207, 34, 171, 0.5])
            var symbol = new esri.symbol.SimpleMarkerSymbol().setColor(new dojo.Color([255, 0, 0]));
            featureLayer.setSelectionSymbol(symbol);
            map.addLayer(featureLayer);
            //Define the geometry service that will be used to perform the buffer.
            var geometryService = new esri.tasks.GeometryService("geometry server url");
            //when the map is clicked create a buffer around the click point of the specified distance.
                map.on("click", function (evt) {
                    debugger;
                    var params = new esri.tasks.BufferParameters();
                    params.geometries = [evt.mapPoint];
                    params.distances = [dojo.byId("distance").value];
                    params.bufferSpatialReference = new esri.SpatialReference({ wkid: dojo.byId("bufferSpatialReference").value });
                    params.outSpatialReference = map.spatialReference;
                    params.unit = eval("esri.tasks.GeometryService." + dojo.byId("unit").value);
                    geometryService.buffer(params);
                geometryService.on("buffer-complete", function (result) {
                    debugger;
                    map.graphics.clear();
                    //draw the buffer geometry on the map as a map graphic
                    var symbol = new esri.symbol.SimpleFillSymbol(
        esri.symbol.SimpleFillSymbol.STYLE_SOLID,
          esri.symbol.SimpleLineSymbol.STYLE_SOLID,
          new dojo.Color([255, 0, 0, 0.65]), 2
        new dojo.Color([255, 0, 0, 0.35])
//                    var symbol = new esri.symbol.SimpleFillSymbol(
//            esri.symbol.SimpleFillSymbol.STYLE_NULL,
//            new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
//            new dojo.Color([105, 105, 105]), 2), new dojo.Color([255, 255, 0, 0.25])
                    var bufferGeometry = result.geometries[0]
                    var graphic = new esri.Graphic(bufferGeometry, symbol);
                    map.graphics.add(graphic);
                    //Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic
                    //as the selection geometry.
                    var query = new esri.tasks.Query();
                    query.geometry = bufferGeometry;
                    featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function (results) {
                        debugger;
                        var totalPopulation = sumPopulation(results);
                        var r = "";
                        r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
                        dojo.byId('messages').innerHTML = r;
        function sumPopulation(features) {
            debugger;
            var popTotal = 0;
            for (var x = 0; x < features.length; x++) {
                popTotal = popTotal + features.attributes['OBJECTID'];
            return popTotal;
            alert(OBJECTID);
            console.log(popTotal);
        dojo.ready(init);
    </script>
  </head>
  <body class="claro">
  <div style="width:99.7%; border:solid 1px; border-color:#CFE5FA; height:99.7%">
  <div data-dojo-type="dijit.layout.BorderContainer"
       data-dojo-props="gutters:'true', design:'sidebar'"
       style="width:100%;height>:100%;"
       <div id="leftPane"
         data-dojo-type="dijit.layout.ContentPane"
         data-dojo-props="region:'left'">
     <div style="background-color:#f1f1f1; border:solid 1px; width:100%; border-color:#CFE5FA; height:30px; font-family:Verdana; font-size:11px;">
     <table cellpadding="0" cellspacing="0" border="0" width="100%">
     <tr>
     <td style="width:13%; text-align:left;">
     <b>Buffer Parameters</b> </td>
     <td style="width:48%; text-align:left;">
      Spatial Reference WKID: <input type="text" id="bufferSpatialReference"  value="32644"  class="inputtxtbox" />
      Distance: <input type="text" id="distance" class="inputtxtbox" />
      <select id="unit" style="width:100px;" class="ddl">
        <option value="UNIT_STATUTE_MILE">Miles</option>
        <option value="UNIT_FOOT">Feet</option>
        <option value="UNIT_KILOMETER">Kilometers</option>
        <option value="UNIT_METER">Meters</option>
        <option value="UNIT_NAUTICAL_MILE">Nautical Miles</option>
        <option value="UNIT_US_NAUTICAL_MILE">US Nautical Miles</option>
        <option value="UNIT_DEGREE">Degrees</option>
      </select>
      </td>
      <td style="width:39%; text-align:left;">
      <button data-dojo-type="dijit.form.Button" type="button" onclick="map.graphics.clear();">Clear Graphics</button>
      </td>
      </tr>
      </table>
      </div>
<%--        <div id="mapDiv" style="height:100%; width:100%"></div>
<div id="mapDiv"</div>
    </div>
    </div>
  </body>
</html>
KenBuja
MVP Esteemed Contributor
To get better answers, you should put your question in an appropriate space and add some tags. I have moved it to the ArcGIS API for JavaScript​ space for you and added tags.
There are some good samples to help you out. Take a look at this sample that uses a value from a text box to create a buffered feature. Then you can use that feature in a Query. There are a lot of examples on here with a quick search.
bharathreddy
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html, body, {
        padding:0;
        margin:0;
        height:100%;
      #messages{
        position:absolute;
        top:10px;
        right:20px;
        padding: 6px;
        border-radius: 4px;
        z-index:99;
        max-width: 150px;
       html, body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow:hidden;
    #leftPane{
      color:#000;
      width:250px;
    #map{
      padding:0;
    .details{
      font-size:14px;
      font-weight:600;
    .ddl
     font-size:11px;
     color:#666666;
     font-weight:normal;
     height:20px;
     width:100px;
    .inputtxtbox
     font-size:11px;
     color:#666666;
     font-weight:normal;
     height:18px;
     width:60px;
    </style>
    <script>
        var map,tb;
        function init() {
                zoom: 14
                    debugger;
                    debugger;
                        debugger;
                        var r = "";
            debugger;
            var popTotal = 0;
            return popTotal;
            alert(OBJECTID);
        dojo.ready(init);
    </script>
  </head>
       <div id="leftPane"
     <tr>
      </select>
      </td>
      </td>
      </tr>
      </table>
      </div>
    </div>
    </div>
  </body>
</html>
