heip me
4983
08-26-2014 09:30 PM
lasinh
functions  queryTask1.execute(query1, showResults) return of type point(only one point), how are getting  this point and pass to functions centerAndZoom(point, lever).
this is my code
queryTask1.execute(query1, showResults);
              function showResults(featureSet) {
                  //remove all graphics on the maps graphics layer
                  myMap.graphics.clear();
                  //Performance enhancer - assign featureSet array to a single variable.
                  var resultFeatures = featureSet.features;
                  //Loop through each feature returned
                  for (var i = 0, il = resultFeatures.length; i < il; i++) {
                      //Get the current feature from the featureSet.
                      //Feature is a graphic
                      var graphic = resultFeatures;
                      graphic.setSymbol(symbol1);
                      //Set the infoTemplate.
                      graphic.setInfoTemplate(infoTemplate);
                      //Add graphic to the map graphics layer.
                      myMap.graphics.add(graphic);
map.centerAndZoom(???, ????);
RainerSpitzer1
You are welcome. If you want you can mark my reply as correct answer to your question.
RainerSpitzer1
you can try the following. It is not tested, but should work. It zooms to the first found feature.
                  if (resultFeatures[1] !== undefined) {
                       myMap.centerAndZoom(resultFeatures[1].geometry, 12);
lasinh
Thanks Rainer!!! I tested and it worked great!!! thank you!!
RainerSpitzer1
