handle/listen Layer visibility events
3409
04-05-2023 02:40 AM
davizuco666
I need to listen to layer visibility changes, but can´t figure out how to do it with Javascript 4.x SDK.
LayerList "trigger-action" never triggers on layer visibility changes.
I Tryed like:LayerList.onLayerList.on
But just working on "load" event..
Also triyed to see all events to find the right one, with no success.
Any ideas?
davizuco666
Auto awnser:
layer.watch('visible', (visibility, a, eventName,layer) => {
                console.log("visible: ", visibility);
                console.log(layer, eventName, a);
I don't understand why there is no mention of this in the documentation, watch is not even in the list of methods.
You just have to guess...
davizuco666
Auto awnser:
KenBuja
MVP Esteemed Contributor
Have you seen this section in the Programming patterns page that discusses watching for property changes?
davizuco666
No I didn´t 😅, it was quite hidden. 🤔  Thank you for the link! 😜
LaurenBoyd
@davizuco666 there is also a sample that shows how to take advantage of reactiveUtils and watch for when the map's layer visibility changes: https://developers.arcgis.com/javascript/latest/sample-code/watch-for-changes-reactiveutils/
It is recommended to use reactiveUtils - here's a blog that discusses the topic more: https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/reactiveutils-and-why-you-should-...
Lauren
