GP Service output 3D Multipatch Supported?
1286
04-04-2019 05:07 PM
YaoMo2
I'm wondering if it's possible to publish 3D Geoprocessing service that returns a multipatch as the output feature?
I have run a 3D buffer tool on a few simple 3D points and created some buffered multipatch. This worked fine with Desktop applications (ArcScene and Pro). Then, I shared the result to the Portal and that also worked fine.
But, when I test the GP service using REST end point, the output feature seems not to have any geometry:
 "paramName": "Output_Feature",
 "dataType": "GPFeatureRecordSetLayer",
 "value": {
  "displayFieldName": "",
  "geometryType": "esriGeometryMultiPatch",
  "spatialReference": {
   "wkid": 4326,
   "latestWkid": 4326
  "fields": [
    "name": "OBJECTID",
    "type": "esriFieldTypeOID",
    "alias": "Id"
    "name": "Name",
    "type": "esriFieldTypeString",
    "alias": "Name",
    "length": 1024
    "name": "BUFF_DIST",
    "type": "esriFieldTypeDouble",
    "alias": "BUFF_DIST"
    "name": "BUFF_QUAL",
    "type": "esriFieldTypeInteger",
    "alias": "BUFF_QUAL"
  "features": [
   {"attributes": {
    "OBJECTID": 1,
    "Name": "Feature 2",
    "BUFF_DIST": 50,
    "BUFF_QUAL": 20
   {"attributes": {
    "OBJECTID": 2,
    "Name": "Feature 1",
    "BUFF_DIST": 50,
    "BUFF_QUAL": 20
  "exceededTransferLimit": false
The geometry type is recognized as "esriGeometryMultipatch". But, is the front-end (JS 4) able to use this result and display in a 3D Scene App?
Any examples with GP tools on 3D features? especially multipatch?
Thanks for any sugguestions
Regards,
Yao
RussRoberts
Esri Notable Contributor
The multipatch feature layer would have to be published as a 3D Object Scene Layer
