Get Layer Name
2314
12-12-2012 05:18 AM
ChrisSergent
I am attempting to display the name of a layer in an alert box. I have attached the .NET project. Here is the JavaScript code that I am using with a comment above the line where I am attempting to get the name of the layer. Any ideas what I need to do? :
<script type="text/javascript">
        dojo.require("esri.map");
        dojo.require("esri.layers.agstiled"); // cached map service.
        var map;
        function init() {
            map = new esri.Map("mapDiv");
            dojo.connect(window, 'resize', map, map.resize);
            var baseMapURL = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
            var basemap = new esri.layers.ArcGISTiledMapServiceLayer(baseMapURL);
            map.addLayer(basemap);
            // I want this alert to display the layer name which should be Topographic Info.
            alert(basemap.layerInfos[0].name);
        dojo.addOnLoad(init);
    </script>
Thanks.
Chris S.
ReneRubalcava
Esri Frequent Contributor
You'll want to listen to the 'onLayerAdd' event when adding individual layers.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi/map.htm#onLayerAdd
So something like
dojo.connect(map, 'onLayerAdd', function(){   alert(basemap.layerInfos[0].name); });  map.addLayer(basemap);
Right now you're trying to access the layerInfos immediately after adding it to the map, but you have to wait for it to finish loading before you can interact with it.
You might even be able to listen to the individual layers onLoad, but I haven't tried that way.
http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jsapi/layer.htm#onLoad
ReneRubalcava
So something like
ChrisSergent
This worked perfect. Thanks Rene.
So something like
