Get DisplayField from Layer loaded via WebMap
536
05-12-2026 12:04 AM
SebastianKrings
we are loading our map from a WebMap which also contains all layers defined as part of the webmap via portal.
const webMap = new WebMap({
    portalItem: {
await webMap.load();
map = webMap;
Unfortunately the field "DisplayField" is undefined for every layer.
This is how a layer looks on the service:
Why is it empty in JS after loading the webMap?
How do I get it otherwise?
Sage_Wall
It sounds like all the layer's haven't fully loaded, what happens if you use WebMap.loadAll()
Sage_Wall
SebastianKrings
Works great + Loads Basemap as Layer which wasnt there before using .load() only.
