4.x Documentation is no longer accessible. There should be an archive we can access of the older docs
2891
14
03-10-2026 09:39 AM
BrentPorter
Hello All
I am helping teach some developers who started with JavaScript API 4.3x about 2 months ago. When the update to 5 happened, the older documentation disappeared.
Are there any plans to make accessible the previous version or the previous n-2 versions of the documentation for the API? This is very disruptive and hard to navigate.
As a hack, I can see some of the material from the Internet Archive (aka Wayback Machine) but every page/link I click has to go back to the timeline which is not sustainable.
2 Solutions
BjornSvensson
Esri Alum
As @WesleyO mentioned above, the SDK documentation for older versions are available for downloads.
In addition, starting hopefully next week, the 4.34 documentation will also be available on a public archive site so that you will not have to download and host it yourself.
BjornSvensson
Esri Alum
There's are some broken links that we'd like to get fixed before officially announcing but if you don't mind that, you can look at the 4.34 docs on the archive site: https://archive.developers.arcgis.com/javascript/v4-34/
MichaelVolz
Esteemed Contributor
When did ESRI start adopting JavaScript API 5.x?
Will JavaScript API 4.x apps start having issues in newer web browsers?
BrentPorter
Forgot to add - it was the week of February 26 that they started using 5.0. Just in time for the Developer Summit in March (this week)
BrentPorter
I don't think that's the issue - the CDN still has accessible versions of the earlier software. But for learning/documentation of existing projects, the older documentation is very hard to work with or not accessible. There is probably some link I am missing or something. But I can't find it so here I (we) are. 🙂
WesleyO
Hi  @BrentPorter , the documentation for older versions are accessible through downloads: https://developers.arcgis.com/javascript/latest/downloads/
@MichaelVolz  , The move from 4.x to 5.x is just a semantic versioning change. Major updates, including deprecation and breaking changes, are expected in 5.0, but it will not require a complete application rewrite. You can learn more about our decision to do this here: https://www.esri.com/arcgis-blog/products/js-api-arcgis/announcements/arcgis-maps-sdk-for-javascript...
I don't see any reason for the recent versions of 4.x to be running into issues with web browser updates. If this is a concern, I recommend that your app is regularly updated to the latest version of the Maps SDK.
Let me know if there are any questions.
BrentPorter
Thanks for the links! I'll check it out and respond back here if everything seems to be available with working links, etc.
BjornSvensson
Esri Alum
BrentPorter
Hello again Bjorn! Any luck with getting the older versions available on a public archive site?
-Brent
BjornSvensson
Esri Alum
BrentPorter
Thank you - I will gladly take a few broken links in the interim to be able to access this.
Much obliged,
Brent
