Get "Value" from Dijit option, Yeah Right...
3756
11
08-10-2010 01:07 PM
KeithSandell
Once again I have spent too much time working on this to feel intelligent any longer.
I've implemented a dijit.form.ComboBox, followed by a dijit.formButton:
The idea here is after the user selects a "displayed value" in the combobox, they click the button and fire off a function that does something based on the "value" of the selected item (<option value="someValue">).
I can get the "displayedValue" all day long and have found many ways to do that, but I simply cannot get inside the option to get the value of its attribute "value."
I've read more dijit and dojo reference than I care to admit and have tried everything I can find on the web, but to no avail.
It is kicking my @$$.
Please help!!
Thanks a million.
function getData(){
var selectedVal =  {can't figure this part out};
if (selectedVal == "expired") {
do this;}
else if (selectedVal == "4") {
do this;}
else if (selectedVal == "future") {
do this;}
<div id="dropDown">
<select dojoType="dijit.form.ComboBox" id="selBox" class="dropSlam" value=" Select...">
<option value="expired"> Alex</option>
<option value="expired"> Bonnie</option>
<option value="4"> Colin</option>
<option value="future"> Danielle</option>
<option value="future"> Earl</option>
<option value="future"> Fiona</option>
<option value="future"> Gaston</option>
<option value="future"> Hermine</option>
<option value="future"> Igor</option>
<option value="future"> Julia</option>
<option value="future"> Karl</option>
<option value="future"> Lisa</option>
<option value="future"> Matthew</option>
<option value="future"> Nicole</option>
<option value="future"> Otto</option>
<option value="future"> Paula</option>
<option value="future"> Richard</option>
<option value="future"> Shary</option>
<option value="future"> Tomas</option>
<option value="future"> Virginie</option>
<option value="future"> Walter</option>
</select>
</div>
<div>
<button dojoType="dijit.form.Button" type="button" onClick="getData();">Retrieve Data
</button>
</div>
KeithSandell
You have to be careful when you declarativily...Hope this helps.
Thanks for the info. I'll keep this in mind if I run into a situation where a declarative implementation is best.
But for the time being I have kinda fallen for implementing them progromatically. It keeps the HTML to a minimum and since my lists are fairly large I like using the json becuase I can keep it in a seperate js file.
MichaelGaigg
Get the selected item from the onChange event
   this.reportsDropdown = new ComboBox({
    store: _this.reportsStore,
    disabled: false,
    searchAttr: "label",
    onChange: this.reportsChangedEventHandler
   }, this.cboReports);
  reportsChangedEventHandler: function() {
   var report = this.item;
   console.log("Report selected: " + report.value);
   topic.publish("/Reports/changed", { report: report });
