Get "Value" from Dijit option, Yeah Right...
3681
11
08-10-2010 01:07 PM
KeithSandell
Once again I have spent too much time working on this to feel intelligent any longer.
I've implemented a dijit.form.ComboBox, followed by a dijit.formButton:
The idea here is after the user selects a "displayed value" in the combobox, they click the button and fire off a function that does something based on the "value" of the selected item (<option value="someValue">).
I can get the "displayedValue" all day long and have found many ways to do that, but I simply cannot get inside the option to get the value of its attribute "value."
I've read more dijit and dojo reference than I care to admit and have tried everything I can find on the web, but to no avail.
It is kicking my @$$.
Please help!!
Thanks a million.
function getData(){
var selectedVal =  {can't figure this part out};
if (selectedVal == "expired") {
do this;}
else if (selectedVal == "4") {
do this;}
else if (selectedVal == "future") {
do this;}
<div id="dropDown">
<select dojoType="dijit.form.ComboBox" id="selBox" class="dropSlam" value=" Select...">
<option value="expired"> Alex</option>
<option value="expired"> Bonnie</option>
<option value="4"> Colin</option>
<option value="future"> Danielle</option>
<option value="future"> Earl</option>
<option value="future"> Fiona</option>
<option value="future"> Gaston</option>
<option value="future"> Hermine</option>
<option value="future"> Igor</option>
<option value="future"> Julia</option>
<option value="future"> Karl</option>
<option value="future"> Lisa</option>
<option value="future"> Matthew</option>
<option value="future"> Nicole</option>
<option value="future"> Otto</option>
<option value="future"> Paula</option>
<option value="future"> Richard</option>
<option value="future"> Shary</option>
<option value="future"> Tomas</option>
<option value="future"> Virginie</option>
<option value="future"> Walter</option>
</select>
</div>
<div>
<button dojoType="dijit.form.Button" type="button" onClick="getData();">Retrieve Data
</button>
</div>
derekswingley1
I ran into this in the past and got around it by using a filtering select. Same appearance and functionality but you will also be able to get to your "hidden" values.
Edit:  try it out here:  http://archive.dojotoolkit.org/nightly/dojotoolkit/dijit/tests/form/_autoComplete.html?testWidget=di...
Run this in the firebug console:
dijit.byId("setvaluetest").get('value')
dijit.byId("setvaluetest").get('displayedValue')
KeithSandell
swingley;31358 wrote:
I ran into this in the past and got around it by using a filtering select. QUOTE]
Thanks. I tried the Filtering Select as an alternative earlier, but it broke my application. Firebug references a line in ESRI's api:
http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.0
line 16
Its throwing error, "node is undefined". I'd paste the code, but it is way too long.
I have dojo.require for it so I know its not that.
Any other alternatives/thoughts. I tried with std select, but it returns ~.get("value") is not a function.
derekswingley1
Make sure you're passing a valid node ID to the filtering select constructor...if you've got a lot of code, maybe just upload it as an attachment?
ScottDavis
I agree with Derek; FilteringSelect is the way to go. This is what mine looks like:
<select dojoType="dijit.form.FilteringSelect"
 id="queries-combobox"
 name="queries-combobox"
 onChange="changeQuery(this.value);"
 style="width: 100%;">
  <option value="-1">Please select a query...</option>
  <option value="0">Precision Cutting History</option>
  <option value="3">Concrete Raising</option>
  <option value="6">elev diff >= 1/4" WITHOUT tree</option>
  <option value="9">elev diff >= 1/4" WITH tree</option>
  <option value="12">spalled <= 2"</option>
  <option value="15">cracked <= 2"</option>
  <option value="18">sunk <= 2"</option>
  <option value="21">elev diff >= 1" WITHOUT tree</option>
  <option value="24">elev diff >= 1" WITH tree</option>
  <option value="27">waterway hazard = 1 or 2</option>
  <option value="30">ADA - ramp needed</option>
  <option value="33">ADA - has tile (C or F)</option>
  <option value="36">ADA - glue down rubber mat</option>
  <option value="39">ADA - normal</option>
  <option value="42">ADA - non-standard</option>
  <option value="45">Tree Haz(1,2's) OWNER vs CITY</option>
  <option value="52">Management Intern Projects</option>
  <option value="57">ADA Contractors</option>
  <option value="82">Current Projects</option>
  <option value="85">Bomanite (Stamped Concrete)</option>
  <option value="88">Painted Hazards</option>
</select>
KeithSandell
I'd love to use the Filtering Select, but I can't even get as far as passing anything with or to it.
When I set the dojoType="dijit.form.FilteringSelect" my app won't even load, and it throws the error I mentioned earlier.
Just want to check, but what api version are ya'll using?
derekswingley1
I've used Filtering Selects since v1.2 of the JS API.
KeithSandell
You're right. It does work at 2.0.
I just took an ESRI sample and added a dojo.campus sample to it and it worked without a hitch. There must be something else in my code that is causing a conflict.
Now to find it. I'm looking forward to implementing this so I can move on.
But something good did come out of this. I learned a bit about using data stores along the way. That should help trim up my html page code a bit since I have a fair number of drop downs.
Thanks for the help.
KeithSandell
Perhaps I have it wrong, but as of this writing it "appears" that using the declarative method of creating a FilteringSelect box will cause a fatal error in a Javascript Web Mapping Application, i.e. any/all layers will fail to load in the map div.
I got the FilteringSelect to work, but only by implementing it programmtically with a json data store.
RahulRavikumar
You have to be careful when you declarativily add widgets to your JavaScript application, as sometimes the dijit parser is a little slow in building DOM nodes, and therefore sometimes, the DOM node you look for may not be available. To solve this problem, you will need to do the following:
djConfig:"parseOnLoad:false"
dojo.require("dojo.parser");
dojo.addOnLoad(function() {
  //the first thing you do should be to parse all widgets in the page. Only then continue
  dojo.parser.parse();
  //continue with esri.Map (etc.)
Hope this helps.
