GeoRSS examples not working
5718
14
09-26-2012 05:12 AM
ManishGonsalves
I have been trying out the GeoRSS example listed here (http://help.arcgis.com/en/webapi/javascript/arcgis/samples/layers_georss/index.html). Unfortunately it doesn't seem to work as expected. The external GeoRSS file is accessible in the browser directly. The data from the file is however not getting displayed on the base map as polygons or points.   Is there any browser side setting that I have to do to get it working? The documentation doesn't say anything apart from ensuring that the GeoRSS file be publicly accessible.
derekswingley1
Thanks for all your replies. The fix works as expected. In addition, the entire thread answered a lot of questions I had around using GeoRSS for displaying a customized layer on top of a Base Map.
Glad we could help!
derekswingley1
The only way to use the KML and GeoRSS layers will be through this hard-coded online service
Our KMLLayer and GeoRSSLayer are not the only way, but they're the simplest, most straightforward way and it's what we recommend.
Even people who have their own purchased installation of Portal won't be able to point the layers at it
No, I said the opposite of that:  if you purchase Portal, it includes these services and you do not need to use the KML and GeoRSS utility services hosted by Esri as you will have your own services running on your intranet.
__Rich_
I should have been more specific earlier, I'll try again:
If we do have a local Portal install how do we point the JS API at it?  (so that the KML and GeoRSS layers use it, which settings do we change?)
derekswingley1
Good point. We'll likely end up doc'ing these config settings.
Also, the service URL on arcgis.com has been updated so no need to use the work around I posted previously and the GeoRSS Layer sample is working.
__Rich_
Thanks for the response, yep, that's what I was getting at - that's good news 🙂
