Open Button from Middle
1364
09-26-2012 09:50 AM
CraigMcDade
I'd like my buttons to open the content pane from either the middle or right of the content drop down. The default seems to be from the left side. I'm running into issues with the content going off the page and causing the user to need to scroll right. Any ideas?
CraigMcDade
using dojo.fx.Toggler. Wound up getting it to work by using a little css. My original css wasn't working because I had set position:absolute;
Once I changed it to position:relative; I was able to add a right:80px; to move the drop down to look centered under the button.
derekswingley1
What dijits are you using? As always, repro code would go a long way :).
CraigMcDade
derekswingley1
Nice, glad you got it figured out.
