Generated token not able access my webmap
856
10-23-2024 11:40 AM
naveenbesri
I have generated token using my ArcGIS online credentials as provided below
https://developers.arcgis.com/documentation/security-and-authentication/app-authentication/client-cr...
When I try to access my webmap  iam not able to access using the generated token. Kindly let me know what is the procedure to access my webmap using JavaScript API.
Thanks
Naveen
RamaniGanason
After getting the token, you will need to register the token using the following function: https://developers.arcgis.com/javascript/latest/api-reference/esri-identity-IdentityManager.html#reg...
That should allow you to access secured resources.
Tags (1)
