generate image by click event
3938
10
12-03-2018 09:58 AM
Pa_Lotus
I'm trying to find a way for
by click event on feature layer,   generate image from lat, long or address of that location and pass the image to layer attributes and display it in infowindow.
Is there a way to generate image of building from lat, long?
Any help Appreciated
Thanks
RobertScheitlin__GISP
Malla,
??? What are you asking?
Pa_Lotus
hi robert,
i'm looking for generating image on click event
Pa_Lotus
example pic, trying to achieve same scenario
What do you mean generate an image on click event?... That does not make any sense to me.
Pa_Lotus
i'm not sure this can achieved, but am looking to achieve scenario  as below image
to show image in info window,
i need to get image from lat,long values and display
Malla,
  Well a lat and lon do not magically make an image. Do you have some web service that will return an image based on a lat and lon?
Pa_Lotus
no, have to create one
Malla,
   Do you have some large directory of images for your geographic area that is cataloged by lat lon?
Pa_Lotus
Robert,
 i have nearly 20 features to show images, the count is not constant it may change
