FormTemplate ExpressionInfos not working
1085
11-11-2023 05:46 AM
JanHellenberg
I am using FormTemplate in a FeatureForm to show elements from a Featurelayer, which works fine. But when I try to replace the field with a calculated expression using the FormTemplates ExpressionInfos, nothing happens and the value from the Featurelayer field is still showing. I have tried with 4.27 and 4.28 and I get no errors in console.
const featureForm = new FeatureForm({
view: view,
layer: MyLayer,
feature: view.popup.selectedFeature,
formTemplate: {
expressionInfos: [
  title: 'Test'
  expression: '$feature.Field2',
  returnType: 'string',
elements: [
  new FieldElement({
  type: 'field',
  fieldName: 'Field1',
  label: 'Label: ',
  valueExpression: 'Test',
So, in this simplified example I would like to display the Field2 value (as calculated in the expression) instead of Field1 but Field1 is still displayed. Of course, my plan is to perform a more complex expression once I get this to work. Can someone help?
ThomasHarner1
Hi Jan,
From what I understand it appears that a Field Element in a Form is pretty strict about the schema/rules of the underlying table/servcie endpoint, and cannot return a value from an ExpressionInfo unless that targeted field is set to not be editable.
Try and add the line "editableExpression: 'return false'" below the valueExpression parameter and see if the value shows up then. I think the idea with valueExpressions is that they dynamically calculate other fields based on another and are not intended to be directly modified by a user.
Thomas
