Formatting the space between widgits
1553
08-22-2017 08:24 AM
GregSalvador
Hi all,
I am putting several widgets in my mapView. Everything works fine, but I have noticed there is a gap in-between the widgets that I didn't define. Is there a way to change how big the space is? Here is the code I am using, nothing fancy:
//LayerListWidget initialization
var layerList = new LayerList({
view: view,
view.ui.add(layerList, "top-right");
//initialization of the basemapGallery widget
var basemapGallery = new BasemapGallery({
view: view,
view.ui.add(basemapGallery, {
position: "top-right"
//initializing the Scale Bar widget
var scaleBar = new ScaleBar({
view: view,
unit: "non-metric"
view.ui.add(scaleBar, {
Tags (1)
ThomasSolow
In the top-right ui holder, the space between widgets is decided by margin-bottom, so you could add a new CSS rule like:
.esri-ui-top-right .esri-component{
  margin-bottom: 0;
sample: JS Bin - Collaborative JavaScript Debugging
(default is 10x, 0 results in some overlap)
ThomasSolow
  margin-bottom: 0;
GregSalvador
Thanks a bunch Thomas, i uhhhh never thought to check the css style haha.
