FeatureTable from client-side GeoJSONLayer not displaying
1665
11-29-2023 09:42 AM
dwismer
I can't seem to get the FeatureTable to display from my external data source (client-side GeoJSONLayer). When I look at the elements, the #tableView div is empty.
Is there an example of creating a FeatureTable from a client-side layer?
Thanks.
UndralBatsukh
It should work like any other layer. Here is a simple example: https://codepen.io/U_B_U/pen/VwgGBPM
dwismer
Thanks @UndralBatsukh , I can't seem to get that link to open to your example.
UndralBatsukh
That is because I posted a wrong link. Sorry about that. Here is the right link: https://codepen.io/U_B_U/pen/VwgGBPM
dwismer
Thanks, the link works.
I am still spinning the tires. I may need to explain my use case a little more.
I have a file upload UI element where a user can submit a shapefile. I then take that shapefile and convert it to a GeoJSONLayer. I have successfully been able to add it to the view to display as well as configure the pop-up to work. But still no luck with the FeatureTable. Is it possible to create the FeatureTable and display it dynamically (ie. once the uploaded file displays on the map)?
dwismer
Apologies, I had my "require" calls all out of order... I got it all to work. Thanks!
