FeatureLayer Difference in Source vs. ApplyEdits
849
02-28-2023 12:33 PM
PatrickMaguire
I've noticed a discrepancy when creating a feature layer. If I add a graphic when creating the feature layer using the "source" property, I get a different visualization vs. adding the exact same graphic using "applyEdits".
The visualization difference is related to overlapping polygons. I want the overlapping polygons to show where the overlap is, and it only happens with source, not with applyEdits.
I've created a example codepen: https://codepen.io/pmag1234/pen/OJoWoVY
The two polygons should both have lines down the middle, but only the one loaded via source does.
Thanks in advance for any help or suggestions!
Patrick
Lerman
There is a topological error of self-intersection of the geometry.
Due to the existence of common edges, each part should be treated as a separate graphic.
If your purpose is to check the graphic for topological errors, you can directly use the geometryEngine.isSimple() method (https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-geometryEngine.html#isSi...).
