esriSimpleSlider opacity
2061
03-23-2012 07:25 AM
GregoryDillon
How do I set the opacity on the esriSimpleSlider
I've tried:
.esriSimpleSlider div
    height: 40px !important;
    width: 60px !important;
    color: Black;
     filter: alpha(opacity=50, style=0);
    -moz-opacity: 50%;
    opacity: 0.5;
    padding-top: 10px;
This does lighten my black to gray (so its doing something), but does not allow me to see throught the background of the slider to map underneath.    I seems I need another div or something to target to a adjust it further, but don't know the ID of that tag.
derekswingley1
Try this:
dojo.style(dojo.byId("map_zoom_slider"), "opacity", "0.5")
GregoryDillon
Try this:
I duplicated the sample http://help.arcgis.com/en/webapi/javascript/arcgis/demos/mobile/mobile_simplemap.html
and tried inserting this code just after the " dojo.require("esri.map");" statement and it can't find the element.   I also tried it just after the " function init() {" line and it failed too.
Is the letter casing correct for "map_zoom_slider"?    If its correct, can you please tell me where to insert this line and/or test it in the sample.
by Anonymous User
Not applicable
You could try either adding a style for the element with the map_zoom_slider id:
   #map_zoom_slider
    opacity:0.5;
    filter:Alpha(Opacity=50);
Or...add the dojo.style(dojo.byId("map_zoom_slider"), "opacity", "0.5"); code inside of the "onLoad" callback for the map object (say around line 59 in the original sample).
GregoryDillon
   #map_zoom_slider
    opacity:0.5;
Okay I finally figured this out.   You really want to take note of this!
The map DIV tag MUST have an id="map",  I had mine set to "mapDiv" which worked fine in conjunction with "map = new esri.Map("mapDiv", { logo: false });" statement, but will not allow you to style "map_zoom_slider".   Once I changed the id to "map" and change to javascript statement to "map = new esri.Map("map", { logo: false });" I was good.
This should probably be documented somewhere in the API.
by Anonymous User
Not applicable
If the id for your map div is "mapDiv", then the following alternatives should have worked:
   #mapDiv_zoom_slider
    opacity:0.5;
or in the onLoad callback:
dojo.style(dojo.byId("mapDiv_zoom_slider"), "opacity", "0.5");
Basically, the map div's ID is being used as the initial prefix for the slider's ID.
In Firefox with the Firebug extension, or in Google Chrome, you can usually right-click on an object in the page and "Inspect" an element - this helps identify properties of HTML elements (such as an ID).
