esri tasks locator - not returning any records for single address
553
02-14-2017 03:48 PM
Ravichandran_M_Kaushika
dear Readers,
I followed the example mentioned for amd esri/tasks/locator as Locator.
var geocodeLocator = new Locator("https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
I created a function and the code inside the function was the following:
findAddress: function (streetAddress, countyFIPS, map) {
if (streetAddress.length === 0) {
alert('Please enter an address.');
return;
if (countyFIPS.length === 0) {
alert('County is needed.');
return; }
var searchAddress = { "Single Line Input": streetAddress }; // single element - not an array.
var options = {
address: searchAddress,
outFields: ["Loc_name"]};
geocodeLocator.outSpatialReference = map.spatialReference;
geocodeLocator.on("error", function (error) {
alert('Error code: [' + error.error.httpCode.toString() + '.] ' + error.error.message);
return;
geocodeLocator.on("address-to-locations-complete", function (addressCandidates) {
array.forEach(addressCandidates, function (eachAddressCandidate) {
var test = "";
console.log("results:" + results.toString());
geocodeLocator.addressToLocations(options);
{"spatialReference":{"wkid":102100,"latestWkid":3857},"candidates":[]}
getting an empty address candidates - let alone score . lat long...
any guidance will be greatly appreciated.
regards
ravi.
RobertScheitlin__GISP
Ravi,
   The field name for the single line field is SingleLine. You are trying to use the fields alias name:
    return;
    return;
  var searchAddress = { "SingleLine": streetAddress }; // single element - not an array.
  var options = {
    return;
      var test = "";
Ravi,
    return;
    return;
  var options = {
    return;
      var test = "";
thanks Robert for your help.  I got that information about "Singe Line Input" from esri help pages.
I changed it to singleLine and it worked.
regards
ravi.
