Empty map when using token based authentication with javascript api
3520
6
06-29-2012 04:49 AM
by Anonymous User
Not applicable
Original User: pragnesh.patel
hi all,
i am trying to use my 9.3.1 service in javascript api with token based authentication.
I am getting blank map.
i use proxy mentioned in this post
any idea what can be wrong?
below is my header
[ATTACH=CONFIG]15598[/ATTACH]
& response
[ATTACH=CONFIG]15599[/ATTACH]
by Anonymous User
Not applicable
Original User: ciava.at
have you tried to go debug in proxy.ashx ?
JeffPace
did the break coincide with updating from 2.5/2.6 to something higher? if so there were changes to the security model.
DO you
dojo.require("esri.IdentityManager");
i.e, do you ever get the Login prompt?
by Anonymous User
Not applicable
Yes i have debugged through proxy and it returns correct token.
PragneshPatel
DO you
No i have started fresh application with new 3.0
and it don't ask me any login prompt.
PragneshPatel
do i need crossdomain.xml?
by Anonymous User
Not applicable
It gives same error when i login to the rest services from browser
I my user is member of agsadmin group.
I am able to login to Rest Admin (http://<servername>/ArcGIS/rest/admin/) using the same login. but gives unauthorised access as attached screenshot when i try to login to services directory (http://<servername>/ArcGIS/rest/services)
[ATTACH=CONFIG]15648[/ATTACH]
