Email Link - Shows multiple times with .actionlist
4319
02-06-2015 11:44 AM
KeithAnderson
Friends of the mighty Javascript API-
I have been working with this example in my source:
History API to track selected feature | ArcGIS API for JavaScript
I have been trying many things to keep the Email link to not show up multiple times when it hits query(.actionlist.
I am loading a different single layer each Map Click of a Treeview control. Its always named  "theLayer".
I have tried many other Map events and also checking if the emailLink is already created...without any luck.
map.on("layer-add-result", function (result) {
    if (result.layer === theLayer) {
        console.log('THE layer');
        // Add a link into the InfoWindow Actions panel
        //if (!dom.byId("emailLink")) {
        //    domConstruct.create("span", {
        //        id: "emailLink"
        //    }, query(".actionList", this.map.infoWindow.domNode)[0]);
        var emailLink = domConstruct.create("a", {
            "class": "action",
                "innerHTML": "Email Map",
                "href": "javascript:void(0);"
        }, query(".actionList", map.infoWindow.domNode)[0]);
        //}, "emailLink", "only");
Any suggestions would be grateful
Thanks
Keith
Tags (1)
RobertScheitlin__GISP
Keith,
   I have added a second layer programmatically to that sample and I am only getting one email link... Can you share more of your code?
