edit templatePicker Style
4625
8
01-22-2013 09:47 AM
BrianLord1
I have been trying to edit the default style for the templatePicker shown in the sample below.
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/ed_template_picker
I only have one featurelayer that will be shown in the templatePicker and have gotten everything to work correctly. I am trying to get the background of the templatePicker to be transparent instead of white.
Code:
                    templatePicker = new esri.dijit.editing.TemplatePicker({
                    featureLayers: layers,
                    rows: 1,
                    columns: 1,
                    grouping: false
                }, "templatePickerDiv");
                templatePicker.startup();
HTML code for the editor window that I have adjusted.
<div id="divAppContainer">
            <div dojotype="dijit.layout.ContentPane" id="editContainer" class="divEditorContainer">
                <div id="divEditortitleBackground">
                    <table>
                        <tr>
                            <td>
                                <img src="images/comments_small.png"/>
                            </td>
                            <td>
                                <div id="divEditortitle">Editor Window</div>
                            </td>
                        </tr>
                    </table>
                </div>
                <table>
                    <tr style="height: 30px; margin: 0px; padding: 0px;">
                        <td style="height: 30px; margin: 0px; padding: 0px;">
                            <div class='instructions' style="height: 30px; margin: 0px; padding: 0px;">
                                <ul style="list-style:none;padding-left:4px; vertical-align:top">
                                    <li><b>Create Features</b></li>
                                </ul>
                            </div>
                        </td>
                                <ul style="list-style:none;padding-left:4px;">
                                    <li><b>Edit Existing Features</b></li>
                                </ul>
                            </div>
                        </td>
                   </tr>
                   <tr>
                        <td style="width: 50%">
                            <div id="templatePickerDiv" ></div>
                        </td>
                            <button dojotype="dijit.form.ToggleButton" id="btnSelectEdit" title="Edit Existing Points"
                                    onclick="ToggleEditing();">
                                    <img src="images/GenericPencilTarget32.png"/>
                            </button>
                        </td>
                   </tr>
                   <tr>
                        <td>
                            <button id="undo" class="UndoRedo" data-dojo-type="dijit.form.Button" data-dojo-props="disabled:true, iconClass:'undoIcon'" >Undo</button>
                        </td>
                        <td>
                            <button id="redo" class="UndoRedo" data-dojo-type="dijit.form.Button" data-dojo-props="disabled:true, iconClass:'redoIcon'" >Redo</button>
                        </td>
                   </tr>
                </table>
            </div>
        </div>
Here is some of the many CSS rules that I have tried that does not get me the desired effect.
            .templatePicker .grid{
                background-color: transparent;
            .templatePicker .item{
I am pretty new to Javascript and CSS, so I assume I am either not using CSS correctly or am missing something. Any help would be greatly appreciated.
BrianLord1
Is there a way to select the template using code, instead of actually clicking on it?  Since I only have one featurelayer template, I thought it might be easier to just have a regular toggle button that when clicked, selected my only template from the templatePicker.
Anyone ever tried this or something similar to this?
JennB
Let's bring this thread up...
I'm also running into the same issue. I've tried this, like Mark has, to no avail:
TimWitt2
Jenn,
what visual effect would you like to attain?
Tim
JennB
Tim,
I've included a screen shot below. As you can see, there's a background I'd like to show through the TemplatePicker (that Add Project stuff). I've figured out how to change the font colours quite easily but I'd like the background to be completely transparent. I've tried the background-color:transparent on .templatePicker .grid with no luck and just on .templatePicker but I can't seem to figure it out.
(You can ignore the 'testing testing' box - that's something else!)
Jenn
MatthewLofgren
This may work for you or at least get you started.
.templatePicker .grid .dojoxGridCell {background-color:transparent; border-color: transparent;}
.templatePicker .grid .dojoxGridRow {background-color: transparent; border-color: transparent;}
.templatePicker .grid .dojoxGridRowOver .dojoxGridCell {background-color:transparent}
.templatePicker .grid .dojoxGridRowOdd {background-color: transparent;}
.dojoxGridScrollbox {background-color: transparent;}
.templatePicker {background-color: transparent;}
.templatePicker .grid {background-color: transparent;}
JennB
I would have never come up with that - thank you! I'm new to the JavaScript API (and anything with the word Dojo in it...). It works wonderfully .
MatthewLofgren
No problem. Just use Chrome dev tools (or firebug) to open up all the child nodes of the widget and play with the styles till it works.
PriyaRam
Hi - On similar lines , I would like the Template Picker to have sort of Tree View with a check box , that would display the groupings underneath. Please advise, how I can achieve this.
