Edit Does Not Save in Using the attribute inspector
1155
05-30-2013 03:39 AM
Nadeera_RukshanMemmenda_Arachc
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/ed_attribute_inspector.html
Using above sample, I cannot edit the fields. I tried the live sample. It didn't work. Can anyone help me?
KellyHutchins
Esri Notable Contributor
Its an issue with the proxy on the help.arcgis.com site. Instead of using help.arcgis.com to access the JavaScript help use the developers.arcgis.com site. On that site the proxy is working correctly:
http://developers.arcgis.com/en/javascript/jssamples/ed_attribute_inspector.html
Kelly
ionarawilson1
Kelly, I am having the same issue. Have you figured out the problem? The sample you provided also does not work.Thanks
Kelly
