Duplicate maps
1211
09-24-2025 08:47 AM
JaysonLindahl
I am very new to JavaScript SDK.  I can't figure out why I have 2 maps in my view.
Here is my code:
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no" />
    <title>ArcGIS Maps SDK for JavaScript Tutorials: Display a map using arcgis/map-components</title>
    <style>
      html,
      body {
        height: 100%;
        margin: 0;
  #searchDiv {
        position: absolute;
        top: 10px;
        left: 60px;
        z-index: 99;
    </style>
<!-- Load Calcite components from CDN -->
    <script type="module" src="https://js.arcgis.com/calcite-components/3.2.1/calcite.esm.js"></script>
    <!-- Load the ArcGIS Maps SDK for JavaScript from CDN -->
    <link rel="stylesheet" href="https://js.arcgis.com/4.33/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.33/"></script>
    <!-- Load Map components from CDN-->
    <script type="module" src="https://js.arcgis.com/4.33/map-components/"></script>
  </head>
  <body>
<div id="searchDiv"></div>
    <arcgis-map id="arcgisMap" item-id="8914d03ca2d745bea3beec1155d0614b">
      <arcgis-zoom position="top-left"></arcgis-zoom>
    </arcgis-map>
    <script>
      require([
        "esri/views/MapView",
        "esri/WebMap",
        "esri/widgets/Search",
        "esri/layers/FeatureLayer",
        "esri/rest/support/Query"
      ], function (MapView, WebMap, Search, FeatureLayer, Query) {
        const webmap = new WebMap({
          portalItem: { id: "8914d03ca2d745bea3beec1155d0614b" }
        const view = new MapView({
          container: "arcgisMap",
          map: webmap
        // Add Search widget
        const searchWidget = new Search({
          view: view,
          container: "searchDiv"
        // Once the map loads, get the first operational layer
        view.when(async () => {
          await view.whenLayerView(webmap.layers.getItemAt(0));
          const firstLayer = webmap.layers.getItemAt(0);
          searchWidget.on("select-result", (event) => {
            const resultGeom = event.result.feature.geometry;
            const query = new Query({
              geometry: resultGeom,
              spatialRelationship: "intersects",
              outFields: ["*"],
              returnGeometry: true
            firstLayer.queryFeatures(query).then((result) => {
              if (result.features.length > 0) {
                const feature = result.features[0];
                const attrs = feature.attributes;
                // Custom popup formatting
                const popupContent = `
                  <b>Precinct:</b> ${attrs.PCT_NO}<br>
                  <b>Commissioner:</b> ${attrs.COMMISSION}<br>
                  <b>Website:</b> <a href="${attrs.URL}" target="_blank">View Site</a>
                view.popup.open({
                  title: "Commissioner Precinct",
                  content: popupContent,
              } else {
                view.popup.open({
                  title: "No features found",
    </script>
  </body>
</html>
Sage_Wall
It looks like if you would also need to modify your css rules to give the div a height.  Here's a codepen.
https://codepen.io/sagewall/pen/bNEVwKr?editors=1010
JeffreyThompson2
MVP Frequent Contributor
There are now two ways to make a map in the Javascript API. The old way looks something like this:
          map: webmap
And the new way looks like this:
You did both. So you made two maps. Do one or the other and you should be fine. ESRI prefers you use the new style, so try to go that way.
GIS Developer
City of Arlington, Texas
Sage_Wall
Hi @JaysonLindahl ,
You are mixing the old MapView and widgets API with the newer web components API.  Your seeing two maps because you have an `<arcgis-map>` component displaying a web map and then you are creating a new MapView and adding it to the `<arcgis-map>`.  If you replace the `<arcgis-map>` with a `<div>` it should work, but you might consider taking a look at this tutorial for how to do this all in the new components API.
https://developers.arcgis.com/javascript/latest/tutorials/query-a-feature-layer-spatial/
Sage_Wall
JaysonLindahl
Thank you very much.  I will look into those articles and work to understand the newer components.
