Does editor widget support create feature only?
875
10-09-2014 07:57 PM
StephenLam
I successfully use "Editor widget with simple toolbar" to create a polygon, which let me create feature, editing existing features' attribute and deleting the features. However, I would like to only allow the editor to create feature and edit it, which means editor is not allowed to edit existing or deleting features. Can I achieve this? I have modified some code but it returns me an error:
TypeError {stack: (...), message: "Cannot read property '_init' of undefined"} "TypeError: Cannot read property '_init' of undefined
    at S._editHandler (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/js/esri/layers/FeatureLayer.js:81:21)
    at Object.E.load (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/js/esri/layers/FeatureLayer.js:43:66)
    at http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:635:478
    at c (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:79:221)
    at d (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:79:10)
    at resolve.callback (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:80:350)
    at c (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:79:436)
    at c (http://localhost:55918/Scripts/arcgis_js_api/library/3.10/3.10/init.js:79:436)"
Refering to this sandbox, the code is changed as below:
        var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...",{
          mode: FeatureLayer.SELECTION_NEW,
          outFields: ['*']
